hayden
Elite Member
- Joined
- Sep 23, 2000
- Messages
- 2,745
- Location
- VT
- Tractor
- Kubota L5740 cab + FEL, KX121, KX080, Deere 6120M
This is really only an issue if you plan to trailer the machine.... but those weights strike me as low, or perhaps just incomplete. I have a similar capcity loader on my Kubota L5740 and the loader w/o bucket is 1000. Then add the bucket weight which is 400 lbs. Also, you will likely need to have the rear tires filled and/or have wheel weights to safely and constructively use the loader. That will add another 1000 to 1500 lbs.The approximate shipping weight of a John Deere 4044R tractor with a 440R loader is around 3770 pounds (1710 kg) for the open station version. The 440R loader itself adds approximately 302 kg (665 lbs) in base weight
My machine with loader and bucket and nothing else is about 7500 lbs. I would expect a similarly ballasted 4066 to be right around the same weight. That's a very significant difference vs about 4500 lbs if you are towing with a small to medium size pickup.
