3 point logging winch
/ 3 point logging winch #1
rt9313
Workmaster50
Good day everyone, I just picked up a used Norse 400 skidding winch which I need to put new cable on it. There is only 60 ft of 3/8 cable on it now. I will use this for skidding but also directional felling which I would like to put about 150 ft on. The book shows it will handle up to 200 ft which is more than needed. The book shows the cable as steel wire rope. My question is there any difference between steel wire rope and plain braided steel cable? I have been using a Farmi JL 304 for years with braided cable that has worked great other than the cable fraying which is hard on the hands. Any ideas on this will be greatly appreciated.
/ 3 point logging winch #2
Curious about this myself as to whether there is something special about these cables so they will wind on the drum without kinking. Are some more resistant to fraying? Do the ones with the user replaceable swaged ends require a particular cable?
/ 3 point logging winch #3
Actually, what people call cable, is REALLY wire rope! Different name for the same thing.
SR
/ 3 point logging winch #4
Here is some additional information on wire rope versus braided steel cable. When I read braided cable this is what I was reminded of. This information is from the Riggers Handbook/ Broderick & Bascom. These braided cables were used for lifting locomotives and a lot of other applications. It is lighter weight and flexible versus a stiff heavy wire rope of a much larger size. If I remember correctly the locomotive lift used 4 endless slings in baskets, with 2 spreader bars and 1.25 dia. braided cable. It forms around the 4 lifting hooks nicely. Just some information.
/ 3 point logging winch #5
Buy your cable from an outfit that sells winches like Labonville
Scroll down to find winch cables
A long while ago I bought a used winch from a guy who worked for the power company. He used the wire rope they used for guy wires. Terrible stuff - way to stiff. You want 6 strands made up of fine wire with the 6 strands wrapped on a core also made up of fine wire.gg
/ 3 point logging winch #6
Yes my recollection is the same - the wire rope is finer for these than general cable is so it can wind-up and bend better for this application.
/ 3 point logging winch #7
I prefer swaged cable for logging winch use. The surface is smoother and less subject to snagging, fraying, and picking up bits of debris. It's also stronger than similar diameter cables which are not swaged. I'll second the recommendation to buy it from a place that sells logging winches. They'll know what you need and likely have it in stock.
Tried to post a reply and not sure if it went, that’s why I cut trees rather than computer stuff! I agree bout finding a place that sell winches and equipment. I’m in NW Wisconsin with virtually no options for dealers so I will need to branch out. Thank you all for your thoughts and if I find something that will work I will let you know.
/ 3 point logging winch #9
Labonville and Hud-son both sell replacement cables for logging winches. I believe they each sell both swaged and unswaged cable, though I think Labonville has a limited selection of diameters available as swaged cable. Hudson has a fairly good selection of diameters of swaged, but only in the longer lengths (230 ft). Their unswaged cable comes in 165 foot lengths.
As mentioned in a previous post, I much prefer swaged cable, but it's a good bit more expensive.
/ 3 point logging winch #10
I think there is a Farmi dealer in the LaCrosse area. Not exactly close to NWI, but at least in the region.
/ 3 point logging winch #11
I bought a new cable from Northeast Implements in Spenser, NY. I had to call as they don't have a catalog on line but they are a Farmi parts supplier. They shipped it to me via UPS. Steel 3/8" wire rope weighs about 1/4 lb per foot depending on the particular stranding. Labonville in Goram, NH will also ship it to you.
gg
/ 3 point logging winch #13
Install the new wire rope under significant tension.
/ 3 point logging winch #14
That "wire rope" that he used for the winch which is a 7 wire strand, is probably "guy wire" which is used to anchor poles, and is also used to suspend the conductor wires between poles. I would like to have a penny for every mile of that stuff I made or did QC work on! Depending on the size of each wire, those cables can stand a lot of tensile strength, but bending like wire rope isn't in its design features.
We also manufactured 1.25" wire rope, but the breaking strength of it was over the comfortable capacity of our Tinius Olsen Testing machine, and would shake the machine violently when the cable failed during testing. (somewhere above 85,000 lbs breaking strength) I spent 15 years in that wire and cable plant.
David from jax
/ 3 point logging winch #15
David from jax
David - Where was that plant you worked in?
I spent a couple of decades working for a steel wire manufacturing plant in various capacities. We made tempered spring wire. I still have a part-time connection there.
/ 3 point logging winch #16
Florida Wire and Cable, Jacksonville, Florida. There were 3 wire companies side by side on North Lane Ave and none were competitors. We all made different types of wire.
David from jax
UNUSED KUBOTA M3860 BRUSH GUARD (A62130)
UNUSED KUBOTA...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
2014 FORD F150 4X4 PICKUP TRUCK (A59909)
2014 FORD F150 4X4...
Dexter trailer axles (A61568)
Dexter trailer...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
