used 2016 4044r?
/ used 2016 4044r? #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander1000 6x6, Ego lawn mower and shopping for tractor
Looking at a 2016 4044r with a self leveling loader. has around 950 hours. $32,999 with hydro tranny. What's your thoughts on that price?
/ used 2016 4044r? #3
I'm not familiar with the market for them so can't speak to price. However for the type of work I expect you will do, I think Ag tires would be a much better match than R4 industrial tires.
/ used 2016 4044r?
/ used 2016 4044r? #5
PT1445 1800lbs loader. The articulation allows a short turning radius for working on trails. Here is the spec page: T18 Class
The PT425 is much less expensive, but also very capable of doing a lot of trail kind of work.
/ used 2016 4044r? #6
Arly, are you set on any brand in particular, there are a lot of really good tractors available, but it does not do anyone any good looking at different brands if you only want JD (as an example) and what cost range would you consider?
Tractors that use 6' implements are a good size to consider IMO.
This information helps those that wish to help you. ;)
/ used 2016 4044r?
Kubota and JD are the brands I'm looking at. I'm not sure what "Tractors that use 6' implements" means in this contents?
/ used 2016 4044r? #8
I think he means tractors that have enough HP and weight to operate a 6' rotary cutter...which brings up the question of what tow vehicle and trailer you have to tow that size machine, too.
/ used 2016 4044r? #9
Typically, the width of the loader bucket is around the width of the implements recommended.
The 40xxR series and the Grand L series tractors usually have 6' loader buckets.
Basically, a frame size. Obviously, smaller and larger tractors can use 6' implements.
/ used 2016 4044r?
The approximate shipping weight of a John Deere 4044R tractor with a 440R loader is around 3770 pounds (1710 kg) for the open station version. The 440R loader itself adds approximately 302 kg (665 lbs) in base weight
/ used 2016 4044r? #11
Have you looked at the tractor in person?
/ used 2016 4044r? #13
My first reaction was the price was high. I got on Tractorhouse and there were quite a few available to compare to and the price seems about average. That’s a nice sized tractor and can do a lot of hard work.
/ used 2016 4044r? #14
If it was 400 miles closer I might be tempted to buy it out from under you.... ;) I'd like to have a bigger loader tractor than my current 2720.
/ used 2016 4044r? #15
That summed up my thoughts as well. Initially I was sure the cost was high, only to realize that really it's not. It's no bargain, but Arly wouldn't be raked over the coals. The 4044R is an excellent machine, I find the MSL loader a great option, and an average of 100 hours a year seems pretty good. Not overworked, but not sitting around either. It's an average example of a great tractor, the 4 series are nimble beasts.
I don't know your local market, but this could be a great machine for you.
/ used 2016 4044r? #17
Sounds expensive to me. I bought my 73HP Kioti with cab and loader at 200 hours for $39k. I agree at that the price should come with a cab.
/ used 2016 4044r? #19
Looking at a 2016 4044r with a self leveling loader. has around 950 hours. $32,999 with hydro tranny. What's your thoughts on that price?View attachment 3373770
That's a lot of money for that green paint without a cab.
I would look at another brand.
I bought a 105 HP Belarus 925 with cab and loader with 800 hrs on iit for 5 grand
1990 Ford F700 (A64911)
1990 Ford F700...
2002 Harmon Steel Barrel 7,000 Gallon Asphalt T/A Tanker Trailer (A68183)
2002 Harmon Steel...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
x (A68191)
x (A68191)
2019 RAM LARAMIE 1500 (A67714)
2019 RAM LARAMIE...
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A66736)
2022 East...
