TYM 574 power beyond rear remote w/backhoe
/ TYM 574 power beyond rear remote w/backhoe #11
Does anyone know if there is a parts bundle for adding another remote? I have a backhoe and I ordered a top and tilt so I need to add the third OEM remote. Dealer said it was 1200$. I'd like to shop around to see if I can find it cheaper but I'd rather not have to order each bolt separately.
Why do you *need 3 remotes? You can't use your top and tilt when the backhoe is connected. Just unplug one and plug the backhoe in.
/ TYM 574 power beyond rear remote w/backhoe #12
It's not a need but a want. It's an option, so I want it. Also I have a ditch bank flail mower so I need a third remote if I want to still have the top link working while it is attached.
Also the ag fittings leak more than I'd like so I'd like to be able to leave the top and tilt plugged in as much as possible so the 3rd remote would help with that. Plus the fact there is a 3rd remote option means that they know some people will need/want it.
/ TYM 574 power beyond rear remote w/backhoe #13
Any TYM dealer should be able to sell you the kit. The dealer can install it, or you can do it yourself. It's basically just another valve to go in the stack, longer bolts to put your new bigger stack together, and the lever/linkage to the cab for the new valve. You could also cheat and use a hydraulic multiplier with three sets of ports (or more if you want) leave your top and tilt plugged into that, activate them when you need to make an adjustment, and still have both remotes available whenever you need them. Another sly idea is to get the third remote and put a multiplier with two sets of ports off of it, giving you a dedicated top/tilt control lever with a button to swap between the two.
/ TYM 574 power beyond rear remote w/backhoe #14
I ended up ordering it from a dealer with a reasonable price compared to what my dealer told me. I just wish I could figure out the kit part number clearly so I could google it.
/ TYM 574 power beyond rear remote w/backhoe #15
try 12665084000.
Tractor Tyme, and Tony's Tractor Adventure have both done YouTube videos on the installation. I think Tony's is a bit better. It is the same for the 474 and 574.
/ TYM 574 power beyond rear remote w/backhoe #16
try 12665084000.
Good to know. I see a video from Tony for aa T25. I assume its pretty much the same as a T574.
/ TYM 574 power beyond rear remote w/backhoe #17
Similar but different. The transmission on the T25 is different, but happens to be the same as my venerable T233 and T293 tractors. And, having done the rear remote on my T233, I know they are not quite the same. Tony's T25 rear remote video did help with my T233 project. I have a second valve which I was going to use to put a second rear on my T233. But, I will probably install it on the T293 I just bought instead.
Try this link:
/ TYM 574 power beyond rear remote w/backhoe #18
Try this link:
That reminds me. It's odd that they are painted black from the factory but when you buy them they are unpainted so it looks really bad. I hate painting but I will need to find a black paint when the part arrives
/ TYM 574 power beyond rear remote w/backhoe #19
I know that I am resurrecting an old thread, but I have some valuable information to add on the subject.
1. On my T574, the top set of remotes, labeled "B" is for the backhoe. The lever in the cab has a detente to activate continuous flow for the backhoe.
2. When using this remote, the 3 point lift is not operable.
3. To get full flow to the backhoe, the 3 point arms must be lowered all the way, and the lowering speed control knob must be turned all the way to "fast".
4. You can hook up the backhoe with the 3 point arms still attached, but they cannot lower all the way as they are blocked by the sub frame. I believe this restricts the flow somewhat, but it is acceptable to me for most use cases. Eventually I will get a pressure gauge and find out for sure how much restriction there is.
/ TYM 574 power beyond rear remote w/backhoe #20
It's irrelevant because the remotes are connected before the 3 pt valve. Also, the speed control knob, only affects the speed the 3pt lowers, nothing else in the hydraulic system. It will still let it raise at full speed and, when rotated all the way in, won't let the 3 pt drop.
2022 CATERPILLAR 289D3 SKID STEER (A62129)
2022 CATERPILLAR...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2025 AGT Industrial ATK-B1000 2 Post Car Lift (A60463)
2025 AGT...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A61568)
2003 Ford F-150...
2000 TEREX 60TON T560 REAR WHEEL DRIVE CRANE TRUCK (A59906)
2000 TEREX 60TON...
2018 Toyota Tundra Pickup Truck, VIN # 5TFRM5F11JX133691 (A61165)
2018 Toyota Tundra...
