Rims and tires - JD PR84B ‘Harley rake’
   / Rims and tires - JD PR84B ‘Harley rake’ #1
Dadnatron
Versailles, KY
JD 5100e with FEL
Purchased a used power rake from auction, and I’m trying to find new rims for the front gauge wheels. Just need something that will work, not looking for OEM, unless that’s all I can get. I don’t think the guy that owned this did ANY maintenance nor cared a bit for it. I think he was allergic to grease, the more I get into it. But it’s mine now, so I’d like to salvage it if possible.
I’m unfamiliar with rims such as these. 16.5x6.5-8 is tire size.
I need new rim completely for one side and at least new bearings for the other, although likely new rim for both.
Any help appreciated.
   / Rims and tires - JD PR84B ‘Harley rake’ #2
Just put "16.5X6.5X8 tire" in search string.... Maybe 20 or so sources will popup to research through..... Personally I would spend the extra bucks and get "flat free" (Marathon) tire & wheel...
A standard laminated tail wheel for a bush hog is 15", so it would only be 3/4" shorter. The standard bolt pattern is 4 bolt on 5". They hold up well to abuse, and never go flat. It might be the cheapest, most durable option.
That was a good thought, and I've gone with it. 2 new hubs, axles, tires, and wheels all 50% of what JD wants for 1 wheel/tire combo. I won't be using it alot, so I'm sure it will work fine.
Thanks for the insight.
(4) ROLLS OF MISC CARPET (A54757)
(4) ROLLS OF MISC...
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
Deere 310L (A53317)
Deere 310L (A53317)
5TH WHEELS & HUBS (A55745)
5TH WHEELS & HUBS...
2018 Kubota U17 (A53317)
2018 Kubota U17...
