Homes… Your Thoughts… Old or New?
   / Homes… Your Thoughts… Old or New? #181
My house is 1830s vintage, previous owner took advantage of a state program for the elderly and they did kind of a half-@ssed job insulating. What the crew apparently didn't know was that this house is plank construction, ie-4 x 24" vertical planks notched into the sill and top beam. So basically solid wood walls. At some point in the house's history strapping was put on and drywall installed. The gap between the wall & the drywall got kind of filled with the insulation. When I redid the kitchen & bathroom I got rid of that & used 1" styrofoam board then drywalled over it. Not a very high R value, but at least no gaps. Not sure what the R value of solid wood is. House holds heat fairly well.
In some parts of the house I saw evidence that there were once plastered walls, but in one room I'd gutted there was wallpaper applied directly to the wall planks. I'm guessing that was pretty drafty.
I don't know how much of my house is "original". I did put in modern replacement windows in the upstairs rooms...the sashes were in rough shape. Downstairs many of the windows are the ones that were here when we bought the place, other than the bow window we put in the kitchen.
Once upon a time they made vinyl tracks for double-hung windows, I re-did all the windows in my previous house using them, but when I moved here I couldn't find them...matter of fact, couldn't even find anyone that even knew what I was talking about.
"Not sure what the R value of solid wood is." About R1 for 1 inch of wood. That is why I don't live in a log cabin. We seriously considered a log cabin 30 years ago, we went post and beam wrapped with conventional 2x6 walls for insulation and wiring.
   / Homes… Your Thoughts… Old or New? #182
I had a step-bro who lived in a log cabin. He and carpenter bees were frequent, familiar, and mortal enemies. It seemed his summers were basically marked by months-long battles with the things, to the point where it's almost all he could talk about, for a few months of every year. :ROFLMAO:
   / Homes… Your Thoughts… Old or New? #183
Log cabins tend to be high maintenance. The wood naturally checks, then up here at least they get moisture which freezes in winter and makes them crack more.
Plus there aren't many options when you get tired of looking at the log interior.
  • Good Post
Reactions: JJT
   / Homes… Your Thoughts… Old or New? #184
That sounds like some of the work in my last house.
The old lady we bought the house from had one of her sons work on the place since he was a "Handy" man.
Well he wasn't very handy. I was in the attic shortly after purchasing the home.
I kneeled down and got shocked.
I started digging in the insulation and found where he added some lights. Instead of using junction boxes for the wiring, as well as wire nuts for the connections. He just stripped the wires back, twisted them together, and left them exposed.
I went to home depot and picked up a bunch of junction boxes and covers, as well as a box of romex connectors and wire nuts.
I spent two days in the attic hunting and fixing his electrical connections.
I found 9 connections exposed in the attic.
Look up knob and tube wiring……lots of older houses wired like that.
   / Homes… Your Thoughts… Old or New? #188
Old Soul?
I kinda remember them old boxes when digital signals kicked in….. ut i just junked the old tvs myself. I love the flat screens. My old 19” crt tv weighed like a hundred pounds.
You got that right…
An old Wedgewood range or Philco Refrigerator or 1950’s washer and dryers took men of muscle to move…
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A56859)
2009 Skeeter SL190...
2011 GMC Sierra 1500 4x4 Ext. Cab Pickup Truck (A56858)
2011 GMC Sierra...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
Ryobi BS 900 9" Band Saw (A59076)
Ryobi BS 900 9"...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
