JJT
- Joined
- Oct 13, 2001
- Messages
- 2,075
- Location
- Upstate NY, USA
- Tractor
- Kubota L3710 HST and a Kubota ZD21 60Pro
"Not sure what the R value of solid wood is." About R1 for 1 inch of wood. That is why I don't live in a log cabin. We seriously considered a log cabin 30 years ago, we went post and beam wrapped with conventional 2x6 walls for insulation and wiring.My house is 1830s vintage, previous owner took advantage of a state program for the elderly and they did kind of a half-@ssed job insulating. What the crew apparently didn't know was that this house is plank construction, ie-4 x 24" vertical planks notched into the sill and top beam. So basically solid wood walls. At some point in the house's history strapping was put on and drywall installed. The gap between the wall & the drywall got kind of filled with the insulation. When I redid the kitchen & bathroom I got rid of that & used 1" styrofoam board then drywalled over it. Not a very high R value, but at least no gaps. Not sure what the R value of solid wood is. House holds heat fairly well.
In some parts of the house I saw evidence that there were once plastered walls, but in one room I'd gutted there was wallpaper applied directly to the wall planks. I'm guessing that was pretty drafty.
I don't know how much of my house is "original". I did put in modern replacement windows in the upstairs rooms...the sashes were in rough shape. Downstairs many of the windows are the ones that were here when we bought the place, other than the bow window we put in the kitchen.
Once upon a time they made vinyl tracks for double-hung windows, I re-did all the windows in my previous house using them, but when I moved here I couldn't find them...matter of fact, couldn't even find anyone that even knew what I was talking about.
