Sight glass
/ Sight glass #1
redman1533
Massey ferseson 1533
My eyes are bad, I repaired leak in line, it's so hard to tell fluid in the glass, I may overfilled, or lost way more than I thought..is there any kind of a trick with a colored light? Permatran 3 is hard to tell, wish it had a dip stick.
/ Sight glass #3
Most all hydraulic fluids are hard to see but you can purchase oil dye to color it, I believe on Amascon or your local JD dealer. I say most, but not all. I use Chevron All Weather THF synthetic which comes pre dyed in orange of all things and it's easy to see in a sight glass or on a dipstick.
/ Sight glass #4
ON my MF GC1715 the background color od sight glass is silver, if fluid on in sight glass the portion of background covered takes on a greenish cast.... Otherwise hydraulic fluid die is going to help....
/ Sight glass #5
Mine also is silver; I had the same issue as the OP long ago and didn't realize that I was overfilling because the oil was just barely golden. You don't realize the difference till you've taken a good look at it both ways, and probably don't fully get it until it's too late.
The good thing is that overfilling is at worst going to make a mess when the fluid heats up, expands and then you go up a hill and it blebs out the filler tube...
/ Sight glass #6
I agree...had sight glass L2800HST seem I was always checking the level. 🙄
2003 Dodge Ram 1500 Crew Cab Pickup Truck (A64556)
2003 Dodge Ram...
2014 IC Corporation PB105 School Bus (A64194)
2014 IC...
Bigfoot with Flag (A64557)
Bigfoot with Flag...
2016 Jeep Compass SUV (A64557)
2016 Jeep Compass...
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
