First cutting for the year Oats
/ First cutting for the year Oats #1
Lineman North Florida
Elite Member
LaCrosse Florida
Farmtrac 360 DTC with FEL & John Deere 5093E with FEL ,Kubota SVL 75-2
I posted this in my skidsteer thread but figured it might be more appropriate here, supposed to have good weather for the next week, gonna need it to get these dry without running a tedder through it.
/ First cutting for the year Oats #2
Grass still brown up here in the north.
You cut in dough stage?
I try to cut them in the milk stage if the weather allows, I believe it's different in other parts of the country, some want to cut them in the boot stage, but seeing those seed heads in the roll is what sells down here.
/ First cutting for the year Oats #4
I might try straight oats for hay again.
I tried oats & peas once, weather usually too fickle to cut for hay at right time, and my soil doesn't carry equipment too well when wet.
I mudded that crop out since the oats were starting to mature. Need 4wd to rake that field....
It takes a little luck and some cooperative weather to get a spring oats crop put up.
/ First cutting for the year Oats #6
No tedder or? Why would you not run a tedder right after mowing so they covered the entire field? What little loss there would be would be made up in better, faster, more even drying.
Just a matter of preference I suppose, if I didn't have this 7 plus day window of good weather I would definitely run the tedder over it, but in the past I have had good luck flipping it with a rake and it drying well, I will have to watch it over the next few days to see if it pays off to keep from losing as many of those seed heads.
/ First cutting for the year Oats #8
I ted crop that heavy regardless of weather, but getting 7 days of sun and warm in a row would be like winning the lottery here.
That blows my mind you are baling while I had snow at home yesterday.
Curious what is going in following this harvest? Teff grass or were the oats a companion crop to another seed?
This field has a mix of Bahia grass and coastal Bermuda already established , so after the oats are rolled it will get sprayed in a few weeks for the weeds that will be showing then fertilized and cut in about 6 weeks weather permitting.
/ First cutting for the year Oats #12
In my area I may be able to get 3 cuts typically 2 though. Oats are usually a companion crop for us in the spring and if its a fall crop typically cereal rye is out seed of choice. Always interest me seeing similar methods but with different seeds from other regions.
We have the ability to get 4 hay cuttings if the weather cooperates, BUT it rarely does so it's normally 3 and I try to wait and no till drill in the oats after the first frost so they are not competing with the existing grass as much, I believe I drilled these oats in the first week of December last year. I am like you I like to see what other people do in different parts of the country, I'm always interested in learning.
Got about 1/3 of it rolled today in some of the thinner areas it was on the verge of getting a little drier than I wanted which would have been more like straw if I waited but it turned out pretty good with 44 rolls, I think I can get the rest between tomorrow and Friday.
Got it all rolled this afternoon, wound up with 138 rolls off of this 25 acre field, it took all 7 days to get it dry, I think if I do this again this coming up winter I might try what LHF 2019 suggested and tedd it gently right after cutting to help speed the process of drying, I don't think it would damage the seed heads much if I did it that way.Hope everyone has a fabulous Easter tomorrow and remembers that without Jesus's sacrifice all would be lost.
2020 Deere 670GP (A64126)
2020 Deere 670GP...
Frac Manifold S/A Trailer (A64194)
Frac Manifold S/A...
2022 EZ-GO ELITE...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
