3-Point Hitch Zuidberg front PTO / 3 Point Hitch
   / Zuidberg front PTO / 3 Point Hitch #1
mtnman3321
Member
Kubota L4630
is anyone running a Zuidberg front pto and 3 point hitch?
Is it possible to use a front end loader with that setup?
   / Zuidberg front PTO / 3 Point Hitch #2
I ran across this fella's posts when I got my B2601.
I believe the loader can be fitted at the same time, but it's tight.
I'm not sure about that link.
just type "Kubota front pto" into your search engine.
   / Zuidberg front PTO / 3 Point Hitch #3
The link: Front Linkage Systems | Elevate Your Experience
The look:
   / Zuidberg front PTO / 3 Point Hitch #4
Yes
I guess it’s possible, the upward lift isn’t very high.
Let me clarify, Im asking can I use the factory front end loader when there is a front 3 point hitch
i.e. is there enough clearance between the front 3 point hitch and the front end loader bucket?
   / Zuidberg front PTO / 3 Point Hitch #6
Oh, I thought you meant connecting a bucket to the front 3 point.
Yes, as long as the loader speced for the tractor isn’t too small or overly short armed.
I’ve seen a few tractors with both a front 3 point and a loader. The 3 point should be able to tuck in behind the loader.
2015 Dodge Journey Van (A59231)
2015 Dodge Journey...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
LEEBOY 8510 ASPHALT PAVER (A60429)
LEEBOY 8510...
2015 Toro Sand Pro 5040 Bunker Rake (A59228)
2015 Toro Sand Pro...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2003 Freightiner FLD120 (A56438)
2003 Freightiner...
