Mahindra 5145 3 point will not coming all the way up
   / Mahindra 5145 3 point will not coming all the way up #1
rbouis
2021 Mahindra 5145
My 5145 has 110 Hrs and the 3 point will not raise all the way up. The front load works fine. Any help is welcome.
   / Mahindra 5145 3 point will not coming all the way up #2
Has anything changed that might affect it? Fluid level is good? The lever linkage isn't bent or binding is it?
   / Mahindra 5145 3 point will not coming all the way up #3
Check the lever used to raise the three point. Many have adjustable up or down stops. You may need only to adjust the stop.
All of the stops are out of the way
Level is good. Nothing seem bent. Has been getting worse the last 3 months
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58216)
2015 LOAD TRAIL...
1998 CAT D5M XL (A55272)
1998 CAT D5M XL...
2024 Yakta YXR120 Zero Turn Lawnmower (A57453)
2024 Yakta YXR120...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
2015 MACK CXU613 TANDEM AXLE SLEEPER TRUCK (A59575)
2015 MACK CXU613...
1761 (A58375)
1761 (A58375)
