Mahindra 5145 3 point will not coming all the way up
   / Mahindra 5145 3 point will not coming all the way up #1
rbouis
2021 Mahindra 5145
My 5145 has 110 Hrs and the 3 point will not raise all the way up. The front load works fine. Any help is welcome.
   / Mahindra 5145 3 point will not coming all the way up #2
Has anything changed that might affect it? Fluid level is good? The lever linkage isn't bent or binding is it?
   / Mahindra 5145 3 point will not coming all the way up #3
Check the lever used to raise the three point. Many have adjustable up or down stops. You may need only to adjust the stop.
All of the stops are out of the way
Level is good. Nothing seem bent. Has been getting worse the last 3 months
CASE IH 183 - 8R FOLDING CULTIVATOR (A52708)
CASE IH 183 - 8R...
JOHN DEERE 10 LUG TRAILER RIM (A52708)
JOHN DEERE 10 LUG...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
(2) METAL WELDING STANDS (A58374)
(2) METAL WELDING...
2820 (A58376)
2820 (A58376)
2015 Ford F-750 Stellar 10628 10,000LB 5 Ton Crane Mechanics Truck (A56858)
2015 Ford F-750...
