Kubota L4802 vs MX5400
/ Kubota L4802 vs MX5400 #1
John_Mc
Elite Member
Monkton, Vermont
NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
I currently have a New Holland TC33D that is set up for work in the woods: limb risers with Falling Object Protection of sorts (won't stop a large tree, but will stop a good sized limb), belly pan, grapple for FEL, logging winch, forwarding trailer). I did not like the NH 7308 loader, so ordered mine with the Woods 1012 Loader (slightly larger lift capacity and larger dump & rollback angles). I did not originally buy this tractor with forestry work in mind, but my needs have grown over the years. I now use it working in the woods a lot, and picking up some of the larger logs can be a challenge. I do like that it can get in to space where a larger tractor could never go, but the limitations become an issue at times. I get by with what I have (the forestry work started in about 2006, about 5 years after I bought the tractor). I really should be using something bigger, but since I'm not logging for a living, cutting the big diameter logs shorter, taking more trips and taking my time has worked out - though I did manage to crack the clutch housing a few years ago.
I'd have to start over on the modifications if I got a new tractor. I would also most likely want a larger brush hog and boxblade. My old 5' brush hog has been beat to death and really needs to be retired anyway - I would have replaced it before now, but have been putting it off while trying to make the decision about whether to upgrade to a larger tractor.
I've been considering a Kubota L4701/L4802 or an MX5400. The L4701/L4802 only has about 500+ lbs greater lift capacity to full height than what I have now. The MX5400 has about double my current lift capacity (about 1100# more than my TC33D). The downside is that the MX5400 is physically bigger than I would like to go (almost 70" wide). The real kicker is that one of my favorite modification is the Limb Risers and Falling Object Protection. Adding them means I can no longer fold down the ROPS. At 95.7" tall, there is no way the MX5400 will fit into my garage.
I've been getting by with my TC33D, so I'm sure I could get by a little better with the L4802. The best fit for my forestry work would be the MX5400. However, I'm just not sure I want to go that big, and really don't want to leave a new tractor outside full time. I can afford either tractor, but I'm having trouble justifying a new, larger tractor, when I could continue to "get by" with what I have now. I really can't justify a new tractor PLUS a new building.
I'm having a tough time deciding which way to go: I don't want to buy the L4802 now and then wish I'd gone bigger a couple of years down the road. However, that MX5400 is just so dang big for my other needs. I'm not getting any younger, and sooner or later I'll need to cut back on what I'm doing in the woods anyway... in fact, I probably could just continue to get by with the trusty old TC33D if I had to.
I have a good relationship with my dealer, who sells both NH and Kubota. I looked at New Holland offerings, but really don't like how exposed the hydraulics are on their offerings in this size range. I've not had great experiences with the JD dealer in my area, so I'm not considering them. Nearest TYM Dealer is an hour away and in a direction I rarely travel - further than I want to go if I need something. Nearest Kioti dealer is about 1/2 hour away. Close enough for me to consider, but I know nothing about them - I'd consider them after researching their reputation a bit.
I do suspect that pricing for some of these is going to go through the roof due to tariffs, if it has not already, so that might affect my purchase decision as well.
/ Kubota L4802 vs MX5400 #3
Are you generally happy with your TC33D except you want greater loader lifting capacity? Or are there more considerations at play?
/ Kubota L4802 vs MX5400 #4
See if it's an option to rent a MX tractor and do a few of the chores you need to be able to do ?
I love my MX. It has a heavier duty rear end than the L series...more of a workhorse less of a garage queen.
But if it's too big for your woods that's not going to be good....
/ Kubota L4802 vs MX5400 #5
"garage queen" scootr
like that, similar to the mall cruisers pick up truck crowd
yes, the MX series is a step up from L series. reliable & up to the task for estate tractors. if the OP chooses an open station, they should be fine in the woods. always keeping in mind tractor weight is an oft overlooked advantage in upgrades aside from hp, etc.
/ Kubota L4802 vs MX5400 #7
Front axle and wheel hubs on the MX are beefier than on the L series.
One disadvantage of the L4802 and the MX5400 could be having a DPF system that may want to run regen cycles at times when you want to only operate at idle speeds to run your forestry winch?
Having to retro fit another tractor with a belly pan and limb risers does not sound like fun.
Have you considered adding a used skid steer to handle the heavy lifting tasks?
/ Kubota L4802 vs MX5400 #8
You could split the difference with a L3560. A little more weight and lift capacity than the L4802, not as big as an MX or larger framed Grand L. The L3560 costs less than a L4802 too.
Greater towing capacity would be useful as well, though not critical.
It's possible I might upgrade to a larger logging winch as well. What I have now is rated at 7700#. It's a good match for the TC33D, probably OK with the L4802. The MX5400 could handle more, though I suppose I don't really NEED more - there are not a lot of really large trees in my area.
I have learned bigger is indeed better.
I was looking at L's.....ended up with the M series.
Any of what I'm considering are beefier than what I'm using now.
I do recognize that the MX5400 is more suited to logging, but it's enough bigger to cause some problems for some other uses - and as mentioned, having to store it outside is a bummer. I won;t be keeping 2 tractors. If I get a new one, the old one will be sold. I just have not been putting enough hours on them recently to make it worth keeping and maintaining two.
Definitely going with open station. I'd bash a cab to smithereens working in my woods. I might add a bit more guarding for the operator station than what I have now, but that would be more of a cage than a cab. There are times I wish I had a cab: snow-blowing the driveway in the winter would be less of a pain, but I have good winter gear to wear, so I get by in the few snows we get that are too big for the plow on the SxS.
I did look at the xx60 series (I was looking at the L4060). The problem is that the ROPS models of the L3560 and L4060 are over 97" tall. Too much for my garage. The ROPS models of L3901/3902 and the L4802 are short enough to fit with a minor modifications to the garage. (I dropped the L3901, since I liked the protection on the hydraulics on the L4802 better.)
It's odd that the ROPS tractors are significantly taller than the cab tractors of the same model. I'd have more options were it not for that. I briefly debated modifying the ROPS to match the height of cab tractors, but the manufacturers have such a fit if you merely drill a small hole in a ROPS, that they'd go totally ape about cutting and welding on it.
/ Kubota L4802 vs MX5400 #11
I was going to say me too! but then I saw you have a MX. I was looking at MX and got a M7060 - much better choice for me!
/ Kubota L4802 vs MX5400 #12
You could possibly fabricate a 4 post style riser that would stll allow the mx ROPS to fold independently of 2 new posts supporting the limb risers?
/ Kubota L4802 vs MX5400 #14
What manner of shed do you have? ie if the floor is dirt could you lower the floor level to fit a taller tractor?
That's an interesting idea. If the ROPS folds backwards, it might be possible. I'd also need to look at headroom, but I think that would be OK: if the cab version has the headroom, the ROPS version with a lowered ceiling should as well.
Another possibility would be to just remove the upper, folding part of the ROPS and build the FOPS/Limbrisers up from the fixed base. I could save the upper piece so it could be returned to stock if I ever sold it.
The current storage area is a 3 bay garage: two car bays open in the front, the tractor bay is in the rear and opens out the side. Floor is cement. I had thought about tearing up the floor and repouring it, but it's just not something I'm prepared to do. I think it would mess up the garage too much, and I'd end up with a weird step in the floor right near where the stairs come down.
I have a lean-to off the back of the garage for firewood and lawnmower storage. It's significantly shorter than the garage door (my TC33D will not fit under it with the ROPS up.) Raising the roof on that is tough, since it there is a door right above it. That door is only used for ventilation (there is no balcony or platform above the lean-to roof), so I suppose I could change that to a window and raise the lean-to roof.
The garage does have electricity, which is great for the lighting, running a smart charger, air compressor and various tools. The ground floor is not insulated, but there is a gas line to run the heater in the 2/3 of the upper floor that is insulated/finished. I had a tap installed in the line so I can plug in a propane torpedo heater on the ground floor if I need to work on something in the winter.
Well I think we all know the solution. Buy the MX and build a tractor shelter for it. Maybe a steel carport. You will love the robustness of the MX and it’s far more maneuverable when working in tight places than it appears to be.
I'm trying to figure out possibilities for something like that. The main issue is finding a place for another building that is acceptable to my wife. Getting electricity to it could also be an issue. I would likely have to feed it from the garage panel. That panel is fed as a sub-panel from the house. The garage panel also has a feed going out to a subpanel in the workshop. I'm probably close to maxing out the various panels, but I suppose running some lights and a battery charger in a new building is possible.
MIGHT be possible to put another lean-to off the side of the garage with a dropped floor. Keeping the water from running off the driveway and into the sunken floor would be an issue. I also might have to have the door open out he back, rather than onto the driveway. It would have to attach well up the side of the roof in order to get the height needed for a decent roof slope. Even then, the slope would be shallow enough that I would likely have to shovel/rake the snow off regularly in the winter. I need to talk to my neighbor who is a semi-retired builder (and one of those guys who can build anything) and see what his thoughts are on the options.
As I read over what I wrote in the post above, this is getting to be an expensive tractor: The tractor with loader, modifications for forestry use, new brush hog, new box blade, possibly a larger logging winch, and a building to keep it in. It's probably only a matter of time before I start thinking I need a bigger Forwarding Trailer - those were never cheap, and with the tariffs, I'm betting are not going to get any better (my current Metavic trailer is made in Canada).
/ Kubota L4802 vs MX5400 #17
Have you considered using a heavy wire from the ROPS to the grill guard as a limb riser? Then the ROPS could still be easily folded down to get into the garage. This is what a lot of Jeepers use while out in the woods and it works well.
/ Kubota L4802 vs MX5400 #18
Go big or go home.
I went from a L3301 to an MX5400. The 5400 isn't that much physically larger and I use it within the woods (40 acres).
Get plenty of ballast (filled tires, heavy rear implement).
You can buy a metal carport to keep your MX5400 out of the weather.
I'm assuming you would sell your existing tractor to help fund the new tractor?
/ Kubota L4802 vs MX5400 #19
agree, don't chose your tractor merely given it's storage challenges. get something big enough to grow into. sounds like you're on the right track, though i don't envy anyone purchasing new at this time.
you can always consider used MX series or even small M series Utility. just get a tractor mechanic to check things out, good luck
/ Kubota L4802 vs MX5400 #20
A idea. Look into those freestanding steel carports, maybe behind your garage. A little gravel for the floor and you’re done. Take power from the side of your garage.
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A63118)
BOSS 990 Fuel...
UNUSED RAYTREE RMT48-48" HYD TRENCHER (A62131)
UNUSED RAYTREE...
UNUSED WOLVERINE TDB-11-84W 84" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
2005 Isuzu NQR 4 door box truck with folding gate (A63118)
2005 Isuzu NQR 4...
