John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,691
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
I currently have a New Holland TC33D that is set up for work in the woods: limb risers with Falling Object Protection of sorts (won't stop a large tree, but will stop a good sized limb), belly pan, grapple for FEL, logging winch, forwarding trailer). I did not like the NH 7308 loader, so ordered mine with the Woods 1012 Loader (slightly larger lift capacity and larger dump & rollback angles). I did not originally buy this tractor with forestry work in mind, but my needs have grown over the years. I now use it working in the woods a lot, and picking up some of the larger logs can be a challenge. I do like that it can get in to space where a larger tractor could never go, but the limitations become an issue at times. I get by with what I have (the forestry work started in about 2006, about 5 years after I bought the tractor). I really should be using something bigger, but since I'm not logging for a living, cutting the big diameter logs shorter, taking more trips and taking my time has worked out - though I did manage to crack the clutch housing a few years ago.
I'd have to start over on the modifications if I got a new tractor. I would also most likely want a larger brush hog and boxblade. My old 5' brush hog has been beat to death and really needs to be retired anyway - I would have replaced it before now, but have been putting it off while trying to make the decision about whether to upgrade to a larger tractor.
I've been considering a Kubota L4701/L4802 or an MX5400. The L4701/L4802 only has about 500+ lbs greater lift capacity to full height than what I have now. The MX5400 has about double my current lift capacity (about 1100# more than my TC33D). The downside is that the MX5400 is physically bigger than I would like to go (almost 70" wide). The real kicker is that one of my favorite modification is the Limb Risers and Falling Object Protection. Adding them means I can no longer fold down the ROPS. At 95.7" tall, there is no way the MX5400 will fit into my garage.
I've been getting by with my TC33D, so I'm sure I could get by a little better with the L4802. The best fit for my forestry work would be the MX5400. However, I'm just not sure I want to go that big, and really don't want to leave a new tractor outside full time. I can afford either tractor, but I'm having trouble justifying a new, larger tractor, when I could continue to "get by" with what I have now. I really can't justify a new tractor PLUS a new building.
I'm having a tough time deciding which way to go: I don't want to buy the L4802 now and then wish I'd gone bigger a couple of years down the road. However, that MX5400 is just so dang big for my other needs. I'm not getting any younger, and sooner or later I'll need to cut back on what I'm doing in the woods anyway... in fact, I probably could just continue to get by with the trusty old TC33D if I had to.
I have a good relationship with my dealer, who sells both NH and Kubota. I looked at New Holland offerings, but really don't like how exposed the hydraulics are on their offerings in this size range. I've not had great experiences with the JD dealer in my area, so I'm not considering them. Nearest TYM Dealer is an hour away and in a direction I rarely travel - further than I want to go if I need something. Nearest Kioti dealer is about 1/2 hour away. Close enough for me to consider, but I know nothing about them - I'd consider them after researching their reputation a bit.
