Are we OK with how bright headlights are getting?
/ Are we OK with how bright headlights are getting? #41
The issue with aftermarket LED bulbs in headlight assemblies designed for Halogen bulbs is, the reflector pattern in the assembly itself isn't designed for LED's, so, the emitted light pattern would be ideal and a halogen reflector will cause a lot of stray light to be emitted. Couple that with cheap LED capsules and you have a light ;mess; that can blind oncoming drivers even when your low beams are energized. I tried a set of them in my F350 (see Haydude I got it right this time....lol) and they were horrible. Headlight assemblies designed for halogen bulbs, don't work well with LED capsules. They do work better with high pressure sodium capsules but they require a ballast to work and are more expensive to purchase.
Then we have the wacko colored LED capsules in blue, green, yellow and who knows what else for the 'kool' look...
Like I said... If I was a cop....lol
/ Are we OK with how bright headlights are getting? #42
Another issue I have with these focused beam LED's on oncoming vehicles is, when they go over bumps in the road, I think they are flashing me. I then flash mine to let them know I have the low beams on. This starts the "flash war" until we pass each other
I have learned to expect that so ignore them... after checking to ensure that my lights are indeed on low beam.
/ Are we OK with how bright headlights are getting? #43
And the good ol' days when low beam was 2 lights and high was 4??
/ Are we OK with how bright headlights are getting? #44
On my side, illegal use of high beams is subject to a fine of 200 yuan and a deduction of one driver's license point
But most people think that the punishment is too low
Nowadays, there are more and more cars on the road, and the quality of drivers is also uneven, and many people expect higher penalties to "improve" the quality of some drivers
/ Are we OK with how bright headlights are getting? #45
Good point.
/ Are we OK with how bright headlights are getting? #47
Some of these new LED's cost $100 or more and that's just the bulbs! The labor can also get pricey, especially when you have to dismantle half the front end to replace them!
Especially Stellantis (RAM) pickup trucks. You have to do some serious dismantling of the front end to replace the bulbs and that includes removing the inner fender wells too. My wife's Suburban is marginally better, You have to remove the front grill to access the headlights to replace the bulbs bit I don't see that happening often because she has LED projector lamps and actually every light is LED, even the instrument panel lights.
/ Are we OK with how bright headlights are getting? #48
and the some like a Toyota Corolla can be changed with no tools…
Was away from home and stopped for dinner and after noticed a light out and auto parts store across the street… paid a few dollars walked back and changed the bulb and headed for home…
/ Are we OK with how bright headlights are getting? #49
What year? They don't appear to be easy on a newer model.
/ Are we OK with how bright headlights are getting? #50
/ Are we OK with how bright headlights are getting? #51
The worst offenders I see are the Jeep drivers that run off-road lights. They really piss me off.
/ Are we OK with how bright headlights are getting? #52
My wife just swapped her (incandescent) bulbs out on her '18 Toyota Highlander.
She's planning on getting LEDs someday but hasn't yet.
Our '09 Mazda 3 driver's side headlamp requires a screwdriver to move the air box out of the way to get to the bulb, but it could be worse.
/ Are we OK with how bright headlights are getting? #53
I don't recall the year, but a coworker had an Oldsmobile that you had to remove the right front fender to change the headlight! The left side, you just needed a screwdriver.
Who designs this stuff??
/ Are we OK with how bright headlights are getting? #54
The neighbor had his wife's Chrysler's front end half tore apart to replace a headlight bulb. He called me over and I showed him how to do it in about a minute without taking everything apart. Sometimes you just need to look at it a bit differently.
/ Are we OK with how bright headlights are getting? #56
I drive a lot, a real lot, in 50+ different rental vehicles a year, cars, trucks, SUVs, major cities, mountains, prairie and in the artic so this is something that really resonates with me.
There was always the jacked up 4x4s that were bad and then the F150s seemed to be one of the first with the really bright in your mirror lights when they were behind you at a light. That expended to other trucks and now as mentioned it's a whole new level of stupidity where manufacturers are clearly using loopholes to far exceed the intention of the rules. I live in a rural area and regularly pass a few Teslas, no idea what model but they seem to be the worst offenders, every little bump is a blinding flash.
I also think the advent of digital dashes and touchscreens has made stupid bright headlights not just a selling feature but a necessity since there is so much light inside the vehicle. The lowest setting for the dash lights on any of these cars is far, far brighter than the highest setting of most pre-digital dashes which I find a huge issue driving through the mountains in the rain at night, even with no other cars around. Automatic high beams compound the problem, they often stay on far too long or come on when they shouldn't. My Model A headlights don't even trigger them so nearly every car with then drives right past with highbeams on. Makes it tough to see for quite a while after that.
The other really big issue previously mentioned is all the LED "upgrades" the market has been flooded with. Very, very few meet any kind of motor vehicle design standards, it's nearly impossible to get the amount of light produced by an incandescent filament from a single point source LED so they use rows and rows of LED chips resulting in a completely unfocussed wall of light scattered everywhere. This gives the impression of great lighting to the person behind the light but a wall of blinding light for the oncoming driver. To meet standards, bulbs need to be precisely focused. 9003 bulbs appear identical to the old H4s however the H4 was not manufactured with the same tolerance for the filament position and didn't meet the testing standard but all that is out the window if you use uncertified LED replacements with rows of LEDs. Not hard to see this by just flipping between low and high beam and comparing where the light goes. Low beam is supposed to be aimed low and cut off at the top, "high" beam refers to the beam projection being higher. I remember some early 9003s were recalled because they didn't meet the new filament tolerance and I got several failed bulbs replaced for free at the time.
grumble grumble grumble... get off of my lawn.
/ Are we OK with how bright headlights are getting? #57
My complaint about the new led headlights is they are HIGHLY DIRECTIONAL. That is if you are directly in front of them you don't get dazzled BUT if there is a rise or dip or on a curve you are dazzled , as they are EFFECTIVELY on high beam.
See Cub7275 (post 55) on why we are being dazzled. This is news to me. Some idiots failed to think things through. HOW did the LIABILITY lawyers miss this one???
/ Are we OK with how bright headlights are getting? #58
I can’t stand those F-360 headlights. They are really bright. 🤪
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
2018 Ford Fusion Hybrid Sedan (A64557)
2018 Ford Fusion...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63688)
2012 MACK Tender...
BUSH HOG 1815 - 15' BATWING ROTARY MOWER (A64277)
BUSH HOG 1815 -...
2020 WESTERN STAR  4900 TRI-AXLE (A65643)
2020 WESTERN STAR...
