Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #24,861
I agree with GG; Geoduck has big hands.
I get 7 1/2 inches from thumb to index fingertips.
I use my bar if I want to measure 16-18 inches. I also have it marked for topping off at 3,4, and 5 inches.
   / Tractors and wood! Show your pics #24,862
Processing white birch now. I like it to burn it spring and fall. Good spring work close to the house when snow is still deep in the woods. Good beech and maple harvested in winter I pile in lengths on flat by the river. Will get to that in a week or two.
Ice is running . Love this time of year.
   / Tractors and wood! Show your pics #24,863
This is my 9" measurement. View attachment 3177548
Outstretched, my thumb to pinkie is 9-3/4. thumb to index is 8-1/2. I eyeball my firewood lengths, because with the IBC totes as long as theyre not over 20-22" I can fit 2 courses deep. If they are, i just stick them out the cutout in the front, or lay them sideways in between the 2 courses. My stove will fit somewhere aroung a 30" front to back, so it all goes in the stove. Do I appreciate a perfectly measured wood stack? Of course, who doesn't? But at the end of the day when I'm loading 8-9 pieces in my stove for the night, I use the long ones I've saved all day. The top of the stove will still boil water at 5:30 am therefore the Mrs. is toasty, and thats all that matters to me!
   / Tractors and wood! Show your pics #24,864
Much of my wood is so bent that I cut what looks right; some of it's 12-14, much is 16, occasionally pieces are 20. It all fits.
I suspect my wife appreciates the smaller pieces.
   / Tractors and wood! Show your pics #24,865
Where do you folks with such large hands buy your gloves ? I usually have to buy double extra large and my hands ain’t as big as some of the measurements I’ve seen here.
   / Tractors and wood! Show your pics #24,866
You need to stretch more ;)
My thumb-to-pinky span is 9.5", but I have pretty flexible hands.
I wear the yellow cowhide gloves in L to XL, depending on the pair and what I'm doing (I hate snug gloves).
   / Tractors and wood! Show your pics #24,867
In addition to overall size, a major factor in this is how far you can spread your fingers/thumb. My hands are far less flexible than they were when I was younger, so I suspect the distance of the spread has changed. My son wears a size smaller glove than I do, and his fingers are a little shorter but his span is the same, maybe slightly larger.
   / Tractors and wood! Show your pics #24,868
When I stretch my hand out, the thumb tip to index fingertip distance is 9". After each cut I hold the saw with my right hand, then span my left hand twice and eyeball a spot on the log for the next cut. I am within a 1/2" of 18" each and every time, depending on gloves or not. At the end of the log I get what I get and that goes in a separate pile. I have never lost my "measuring stick".
I used to have an 11-inch hand span. With arthritis, it's now about 9-inches. Things don't bend like they used to.
   / Tractors and wood! Show your pics #24,869
There is a guy who comes through town about once a month, who does the gloves in all the stores. If I need new gloves, I just let the girls at the local Ace Hardware know that next time he is in, to get me a couple of pair. I like to have a couple of new pairs in the truck, and a pair on the tractor at all times. I have a bad habit of losing and tearing them.
   / Tractors and wood! Show your pics #24,870
Good pile of birch Hoobie. I have a lot of that in the woods to. I do the same as you. I put it in the front and back row of the wood shed. Your beech is all scabby like ours too.
gg
2024 Bobcat T650 Track Skid Steer (A47164)
2024 Bobcat T650...
2015 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A48992)
2015 FREIGHTLINER...
2012 NORMAN POWER SYSTEMS 100KW GENERATOR (A48992)
2012 NORMAN POWER...
2012 PJ  16FT GOOSENECK W/MOUNTED TRANSFER PUMP (A48992)
2012 PJ 16FT...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A49346)
2025 Kivel 48in...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
