F215
johntk
yanmar f215d
I have a yanmar f215 that has a hydraulic lift problem.
So I am currently working on it but nothing has worked out.
Does anyone know where I can find a service manual please.
Regards Shane
Regards Shane
Fredrick's equipment shows F215 Strainer cover. There most likely a Tube type screen/filter behind it. They call it IP-4555 Strainer cover with O-Ring F-20/F-265. Then a filter itself Oil type spin on HF-1120 F14/F215. for '02 & '20 series.
Make sure those are clean and the correct amount of Hyd. fluid. in the reservoir
My guess the Hyd. pump itself is a HP-9AX Splined shaft so no Key way to get sheard on the pumps Dr. shaft itself?. Make sure it pumping fluid?
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
New/Unused 13,000lb Electric Winch (A61166)
New/Unused...
Quick Hitch Skid Steer Attachment (A61567)
Quick Hitch Skid...
New/Unused Leaf Blower (A61166)
New/Unused Leaf...
UNUSED WOLVERINE QMP3-16-6T QUICK ATTACH PLATE (A62131)
UNUSED WOLVERINE...
