Hydraulic Cylinder Doesn't Fully Retract - Normal?
   / Hydraulic Cylinder Doesn't Fully Retract - Normal? #11
Thanks all! I'll measure the stroke today and ask the vendor. My mild OCD will drive me crazy until I figure this out.
Don't you just love OCD.....:)
   / Hydraulic Cylinder Doesn't Fully Retract - Normal? #12
Its possible you have a wee bit of air left in the cylinder that hasnt been bled completely. That would be my first guess on a new cylinder install. Do you have any bounce on the cylinder stroke?
   / Hydraulic Cylinder Doesn't Fully Retract - Normal? #13
I am interested in doing a hydraulic side link on my CK2610. Would you share where you got your cylinder from?
   / Hydraulic Cylinder Doesn't Fully Retract - Normal? #14
Hi All TBN-ers!
I recently put on a hydraulic side link to my Kioti CK2610. It appears that it doesn't fully retract based on the 'silver' reveal. My hydraulic top link does not have this problem. My question to the group: Is this normal? The pic you are looking at is "fully retracted". Can anyone give me guidance?
Thanks!View attachment 655669
Most likely just from how it was taped off before paint.
How far does it extend, 4"?
   / Hydraulic Cylinder Doesn't Fully Retract - Normal? #15
Not the OP, but if you want a side link built to provide an equal amount of tilt to BOTH sides, you might want to try Fit Rite Hydraulics. Most side links available for these models do not provide an equal amount of tilt to both sides and still maintain the left side (OEM) dimensions.
   / Hydraulic Cylinder Doesn't Fully Retract - Normal? #16
Disconnect it from the 3 point hitch (both side) and cycle the piston back and forth with the "bottom" facing up...
   / Hydraulic Cylinder Doesn't Fully Retract - Normal? #17
It's a 5 year old thread. Hopefully the OP has it figured out by now. 🙂
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
2018 Ram 5500 4x4 Crew Cab Flatbed Utility Truck (A55973)
2018 Ram 5500 4x4...
2012 GALLEGOS 130 BBL STEEL VACUUM TRAILER (A58214)
2012 GALLEGOS 130...
2020 DRAGON ESP...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E50NKE58889, Super Cab, 4 x 4, 5.0 L V8 Gas Engine, (A59076)
2022 Ford F-150 XL...
2020 Caterpillar 299D3XE High Flow Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
