Slowpoke Slim
Elite Member
- Joined
- Jan 6, 2017
- Messages
- 3,915
- Location
- Bismarck, ND
- Tractor
- Husqvarna YTH24V48 riding mower, Branson 3725CH
And I'll bet a tire full of molasses runs great at -40 F(C).
Thump, thump, thumpAnd I'll bet a tire full of molasses runs great at -40 F(C).
At -40F I don’t run great and would have no interest in starting my tractor.And I'll bet a tire full of molasses runs great at -40 F(C).
So how has this worked out for you? How did you put it in? My local dealer quoted me $700 in my LS MT347.Just throwing in some info for this thread.
Because of this post I ordered GeoBEET and today was delivered (2)55 gallon drums. They ran $219ea plug shipping.
As for the unloading, I'm trying to determine if I should be happy or bummed about the tractor's performance (LS MT242 w LL3003 loader); it wouldn't curl the load it could carry, running at 2500rpm, about topped out.
Both drums were wrapped on one pallet. The fluid weights approx 11lbs/gal. Giving me 1210lbs of fluid, plus pallet and container weight, and 275lbs of 42" pallet forks/mount. All totaling around 1600lbs. Had the pallet tucked all the way to the mount plate as I could.
The loader lifted the pallet off the truck fine but I could not get the loader to curl so I could lower the load. Had the driver lift gate it to the ground and I picked up the pallet from there, and was able to barely curl the pallet. Of course picking up from the ground the load naturally tilted back when lifted. According to LS specs, max lift capacity @ the pin 2506lb and breakout force @ pin 3723lbs.
I've had the tires loaded now since abt the time I did this post. Very happy with the results. The tractor feels more set, a lot of the bounce was reduced.So how has this worked out for you? How did you put it in? My local dealer quoted me $700 in my LS MT347.
That may very well be the case. I'll revisit it when I can. I'd like to solve it for my knowledge.Sounds like the pressure may need checked and adjusted.
