Good morning!!!!
   / Good morning!!!! #204,711
if you have an EV and want to go in snow up North,
Car and Driver just did a long term winter review of the Kia Ioniq 5 EV and what caught
my eye was the reference to snow tires:
my memory isn't so hot with age but I think one of you have these tires on your car
though this is a new special EV version with what looks like a more closed pattern, less open areas I guess for efficiency.
But let's start our 10,000-mile update on a positive note. Before the snow began to fall in earnest, we equipped our Ioniq 5 with a set of Nokian Hakkapeliitta R5 EV studless winter tires, measuring the same 235/55R-19 at all four corners as the normal all-season footwear. In what is likely the highest praise for a set of snowshoes, our numerous logbook entries barely mention the Nokians. The ride proved just as comfortable as before, and the rubber provided immense amounts of grip when snow did start to fall. Despite some deep treads and sipes aplenty, we didn't run into any issues with annoying tramlining on grooved road surfaces. We've always been a fan of the ol' Hakkas, and it's good to know that the EV-specific variants are just as capable.
pretty sure a Bridgestone Blizzak or Michelin Ice would be almost as good but there seems to be an almost cult
following for these tires. I'd like to send Bill a set of four. Need to keep him out of the ditch... ;)
have always been fascinated by tires. currently the hot ticket is a chevron shaped tread that meets in the middle of the tire.
Michelin has the top rated tire now with an exaggerated version of that tread pattern. Looks like it should be noisy as can be but
apparently not. And grips like mad. Tires are getting better, particularly in bad weather.
Nokians were oem tires on my Ram diesel dually, never heard of them but they turned out to
drive really well. Finnish company with a factory in Tennessee.
   / Good morning!!!! #204,712
54 this morning very windy last night like howling in fact, restock at Walmart 25 mph went to bed at midnight after putting groceries up. Really missing Holly but glad I got to visit with her yesterday. We have a special bond. Mostly neat getting hug from little girl.
This is cool door bell rang last night had fallen asleep deputy sheriff checking on me people really do care you all included. I wish I could sleep
Prayers for all our Country
   / Good morning!!!! #204,713
Good morning! 39˚F heading to 70˚ N wind Sunny skies. Red flag alert is down with decreased winds and 50% humidity.
I was surprised when the painting crew finished yesterday about 4:30. The dry wind made spraying difficult but reduced drying time between coats. The high was 77˚ also helped. House looks good.
Pool pump part will be in Friday, If it still does not work right I will have completed all the requirements for a new pump under warranty.
Pool bots were working hard yesterday and required emptying every few hours. No luck on finding someone to install a pool cover, but still have a few more companies to call.
The deer found the newly planted Costco roses and they appear shorter, but still alive. The deer haven't found the hibiscus in the pots by the pool, yet.
We need rain desperately the .0x" rains don't last long.
Buppies, good post!
Will the vortex/freezing temps come this far South? Next chance for rain?
   / Good morning!!!! #204,714
Coffee done brewing. 46° with partly cloudy skies. Heading to 50° with Rain, Snow and Wind. 72° with sun and clouds
Ron with Snow all the time in Michigan I think your typing fingers automatically migrated to "SNOW" but with those temps I think you will just have rain.
   / Good morning!!!! #204,715
45 outside this AM, heading to 70. Unfortunate rain is expected later this afternoon.
More cutting, splitting, moving and stacking yesterday. Only about 1/2 cord done. Am slowing down from the day before. First time I have cut up an Elm. Wet and stringy. Messy splits. I came across a bone dry piece and man that was a nice smooth split. I see a huge difference between dry wood and fresh wood for sure. Actually can see out the front door now and am slowly working towards the big one.
Need to run out today for domestic errands and call the plumber for a pipe relocation in the Milk House. Finally got the hot water heater cabinet made which hides the hot water heater. Reclaimed barn wood was used, again.
Hope all have a good day. Be safe.
   / Good morning!!!! #204,716
It’s Michigan weather. If you do not like it. Wait a minute. It will change. Forecast shows a drop in temperatures into low 30’s midday. Then back up to 50° later.
   / Good morning!!!! #204,717
Good Morning!!!! 41F @ 4:00AM. Generally cloudy. High 56F. Winds SSW at 5 to 10 mph.
Well deserved good news, Buppies. Hope it keeps on coming.
With the help of my contractor neighbor, we got the firetruck started yesterday. Ran power to the new fuel pump, and had to break through a big rust flake that had blocked the drain hole in the fuel tank. Then neighbor soldered a stand off tube into the barbed elbow that threads into the drain hole to hopefully prevent another blockage. Next step is to see if I can get some water going through the hose.
Also need to get a burn pile going today. Last calm day for a while, with more rain coming tomorrow.
Hang in there gang, Friday's comin'!
   / Good morning!!!! #204,718
Good morning TBN!!
55 now and supposed to get to mid 60s. Wind picking up this afternoon with a low chance of spotty showers.
More work on plan of attack for the bridge. Got it all worked out I think.
Today is going to be a mostly recharge and then start full blown over the weekend. Got a little help coming so hopefully will get most out of the way by Mon. Should be able to move to Phase II next week.
Got some walking and dog time in and a new day awaits.
Time for a second cup
Everyone have a great and safe day!!
   / Good morning!!!! #204,719
Happy spring
38° and drizzle now, highs low/mid 50’s, mostly cloudy today winds SE 5-10 mph. Supposed to see rain late tonight into tomorrow morning. As much as I’d like the mud to dry up we need rain, there’s already been local brush fires popping up.
Not sure about today, may be a good day for a ride and some lunch.
Buppies, we all come here share in some way, continuing prayers.
Enjoy
   / Good morning!!!! #204,720
Scott(vt) hope good day at work. When I retired started singing won't get fooled again, especially the " meet the new boss, same as the old boss..." did not get high praise.
Good Morning Mostly,
Yes, I’m not sure that would go over well. 😉😃
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
UNUSED FUTURE EQUIPMENT SEAT (A58376)
UNUSED FUTURE...
2016 Chevrolet Express 3500 (A57148)
2016 Chevrolet...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
WAKO FERTILIZER (A58216)
WAKO FERTILIZER...
