final leveling of lawn - drag harrow, landscape rake, other?
   / final leveling of lawn - drag harrow, landscape rake, other? #1
orangetree
Gold Member
central idaho
kioti ck2610
I have about a half-acre of lawn to finish. It'll be rough-leveled by a combination of blade/box-blade and FEL float, but from past experience I wouldn't want that to be my final surface. I have a 25hp TLB and a JD lawn tractor.
I've been been considering a landscape rake for this (such as GoodWorks/ or titan import), as I also have some beach/sand area locally I am interested in doing yearly cleanup on. I recall my dad doing my childhood ~1ac lawn with a homemade thing that I believe is called a turf/drag harrow.
The advantage of the landscape rake, a 3pt version specifically, is it seems great for cleaning debris from sand, and forest debris from pine areas, so I have some other stuff to use it with. However, a smaller harrow type unit could probably be pulled behind the lawn tractor which is way(way) less ground pressure - but would it actually even things enough?
The area isn't huge, and I'm no pro with floating the bucket. What should I use to make it a nice smooth final lawn? Thanks!
   / final leveling of lawn - drag harrow, landscape rake, other? #3
I think you may have 2 issues, Leveling the area and Smoothing the area.
Here is a super cheap implement for smoothing the area/seedbed prep, and your sand and woods debris.
   / final leveling of lawn - drag harrow, landscape rake, other? #4
Tow behind version for your lawn tractor.
   / final leveling of lawn - drag harrow, landscape rake, other? #5
I like the idea of a drag harow for leveling, or make something like this.
   / final leveling of lawn - drag harrow, landscape rake, other? #8
If I was going to use just one, it would be a drag harrow. That said, t doesn't take much use to justify a $180 purchase. I think that straw rake would do a nice job of removing the trash, and preparing the seedbed after it has been leveled.
   / final leveling of lawn - drag harrow, landscape rake, other? #9
When I did the final dirt work for our new lawn seed bed I dragged around a big old pallet with a rock box on it so I could adjust the weight. For the beach clean up it would be a pine straw rake for me.
gg
   / final leveling of lawn - drag harrow, landscape rake, other? #10
rent a power rake
KBH 25T Tender (A56435)
KBH 25T Tender...
PALLET OF WOOD & METAL (A58374)
PALLET OF WOOD &...
2016 Chevrolet Express 2500 Passenger Van (A55973)
2016 Chevrolet...
TREE PLANTER (A52708)
1999 CLEMENT END DUMP (A58214)
1999 CLEMENT END...
CLUB CAR PRESIDENT ELECTRIC GOLF CART (A52708)
CLUB CAR PRESIDENT...
