final leveling of lawn - drag harrow, landscape rake, other?
   / final leveling of lawn - drag harrow, landscape rake, other? #1
orangetree
Gold Member
central idaho
kioti ck2610
I have about a half-acre of lawn to finish. It'll be rough-leveled by a combination of blade/box-blade and FEL float, but from past experience I wouldn't want that to be my final surface. I have a 25hp TLB and a JD lawn tractor.
I've been been considering a landscape rake for this (such as GoodWorks/ or titan import), as I also have some beach/sand area locally I am interested in doing yearly cleanup on. I recall my dad doing my childhood ~1ac lawn with a homemade thing that I believe is called a turf/drag harrow.
The advantage of the landscape rake, a 3pt version specifically, is it seems great for cleaning debris from sand, and forest debris from pine areas, so I have some other stuff to use it with. However, a smaller harrow type unit could probably be pulled behind the lawn tractor which is way(way) less ground pressure - but would it actually even things enough?
The area isn't huge, and I'm no pro with floating the bucket. What should I use to make it a nice smooth final lawn? Thanks!
   / final leveling of lawn - drag harrow, landscape rake, other? #3
I think you may have 2 issues, Leveling the area and Smoothing the area.
Here is a super cheap implement for smoothing the area/seedbed prep, and your sand and woods debris.
   / final leveling of lawn - drag harrow, landscape rake, other? #4
Tow behind version for your lawn tractor.
   / final leveling of lawn - drag harrow, landscape rake, other? #5
I like the idea of a drag harow for leveling, or make something like this.
   / final leveling of lawn - drag harrow, landscape rake, other? #8
If I was going to use just one, it would be a drag harrow. That said, t doesn't take much use to justify a $180 purchase. I think that straw rake would do a nice job of removing the trash, and preparing the seedbed after it has been leveled.
   / final leveling of lawn - drag harrow, landscape rake, other? #9
When I did the final dirt work for our new lawn seed bed I dragged around a big old pallet with a rock box on it so I could adjust the weight. For the beach clean up it would be a pine straw rake for me.
gg
   / final leveling of lawn - drag harrow, landscape rake, other? #10
rent a power rake
John Deere 853 20ft Corn Head (A56436)
John Deere 853...
Yamaha (A55758)
Yamaha (A55758)
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
(3) DRILLS (A58374)
(3) DRILLS (A58374)
CAST IRON POTS & KETTLES (A58374)
CAST IRON POTS &...
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
