Using the clutch with a Kubota HST tractor...
   / Using the clutch with a Kubota HST tractor... #1
Redbug
Columbia, SC
Kubota L3830HST
What do you use your clutch for...on your HST tractor...just for engaging the PTO? Or do you use the clutch for other operations?
   / Using the clutch with a Kubota HST tractor... #2
Just for the PTO and may or may not be required to start the tractor.
   / Using the clutch with a Kubota HST tractor... #3
Changing speed ranges
   / Using the clutch with a Kubota HST tractor... #5
I suppose it may help some but, technically, you don't need the clutch to change ranges, since it has to be done with the tractor at full stop anyway.
   / Using the clutch with a Kubota HST tractor... #6
I just need to get the rpm low enough to change range.
   / Using the clutch with a Kubota HST tractor... #7
Owned an HST Kubota since 2004 and only time using clutch is for start;always lock down when not in use.Full stop for range changes.
   / Using the clutch with a Kubota HST tractor... #8
25+ years with a Kubota HST, clutch use is limited to PTO only.
   / Using the clutch with a Kubota HST tractor... #9
Yes^^ Using the clutch may be needed if the HST is not adjusted perfectly to have a neutral position. It can be difficult to change ranges if you have some creep or on a slope.
   / Using the clutch with a Kubota HST tractor... #10
On our l5740 I never use the clutch except to start. I stop to change ranges. I have a GST a M series and the HST and to engage the pto no clutch needed. I do idle down to be easy on the internal pto clutch. On the M5, I have to be rolling to get the big bush hog spinning and not have the engine die. A 2810 is a lot of parts to start moving.
New/Unused CFG Industrial MX20R Mini Excavator (A57453)
New/Unused CFG...
1322 (A58374)
1322 (A58374)
2017 Ford F-150 Pickup Truck (A55973)
2017 Ford F-150...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
CASE IH 1064 - 6R CORN HEAD (A52708)
CASE IH 1064 - 6R...
