Diabetes
/ Diabetes #741
50 is low, to low.
Yes, my doctor says otherwise. Everyone is different. I fell COMPLETELY fine when both my CGM and blood strip has measured 50. I could get my BG to drop significantly at one time when I exercised, EIH. During the night, I learned to turn off the app for the CGM. I also found / heard that if you sleep on the CGM, it would cause low readings.
/ Diabetes #742
Id like to see a "normal persons" daily charting with a CGM. One of the docs told me spiking is normal, but couldnt tell me spiking to what # is acceptable?
what do normal peoples spike too? 150? 175? 200? or is theirs more of a flat stable line across. I can hit a 175 spike from say 85, and withen 2 hours its back down to 100.
Now, if i eat breads or sweets.it may take 3 hours to come back down to 110.
Everyone shoots for different targets. The more insulin resistant you get, the more insulin it will take to get that BG down. It will often take longer to bring it down. Since going low-carb, I never am above 120. I did a few test when I was wearing a CGM and saw a springle cookie put me at 180 for about 30 minutes.
/ Diabetes #743
yes, it sounds off below 60 or above 150. if it wasnt for the CGM id never know when I was low or high. When I was over 600 in hospital they asked me 100 times how i felt. It felt just like any other day to me. No headaches, vision problems, lightheaded etc.
My glucose went to 585 on a weekend in Jan 21. Felt like crap, wife begging me to go to ER. Had been losing weight and in bathroom lots so thought it could be diabetes. Went to walmart and bought meter. 585!, went to doctor on monday and doc said I would put you in hospital if not full of covid. Started me on 2000mg metformin and Toujeo insulin that day.
/ Diabetes #744
I was constantly in bathroom and one of old guys i hunted with who was type 2 said boy your sugar is high. So he went got his tester and it read off the charts so it was over 600. Went to doc in box to confirm and they said same thing. Higher than 600.
they wanted to call ambulance and take me to hospital. I declined and went home and went to a Er closer to home where they admitted me for 2 days.
The prescribed insulin which the pharmacy didnt get any of until about 8 days after released. Id already gotten CGm the 2nd day and was watching it and my #'s were staying down. So I still havent taken any insulin yet and that was about 5 months ago now.
Im just paying attention to what I can and cant eat to keep numbers down and hopefully not have to start using the shots for a few years.
/ Diabetes #745
/ Diabetes #746
The prescribed insulin which the pharmacy didnt get any of until about 8 days after released. Id already gotten CGm the 2nd day and was watching it and my #'s were staying down. So I still havent taken any insulin yet. Just paying attention to what I can and cant eat to keep numbers down.
You are moving around some then? We are out for a ski or hike 6.5 days a week and I take low dose's of humulin
/ Diabetes #749
Never should your graph look like this. While this extreme doesn’t happen like this much anymore I see 400’s on a regular basis. double ups are very common if not every day. Double downs have lessened. No not my graph but someone close. It’s very common to be in the basement and level off at 250-350. I can talk about this all day. To show the extreme this has gone to I finally got it into the court system. Talk about fun.
Not only that but when it stops at HIGH. One can only imagine where one ends up.
/ Diabetes #750
/ Diabetes #751
Dr told me going over 180 is high, if it does not come down below 140 in 2 hours, that's a problem.
My Libre 3 has normal range set, high 180 low 70, Dr want's me to try and stay within that range.
Alarm goes off at 250 or below 70. I hardly ever set off the alarm, always over 250 never below 70
I go over 180 quite often mostly in the very low 200,s but always comes down within an hour, I've only been below 70 a few times in the past year, over 250 once a month or so..
I find it frustrating because what puts me over 200 today may only go to 150 tomorrow.
From reading on here it sure seems we are all different in our reactions to food, but all agree CGM is a life saver.
/ Diabetes #752
I've heard my wife mumble incoherently at 2-3am, checked her level via test strip and it's in the 30s!!! Twice I had to call 911, otherwise if I can get her to take glucose or sugar soda to quickly bring it up that works.
She needs a CGM.
/ Diabetes #753
Do you find it interesting that fruit and grains are two of the top three recommendations, yet for those that are preT2D or T2D, they will make things worse? Get a CGM if you're not sure how your body responds. T2D is rampant in this country and is a leading cause of heart disease.
/ Diabetes #754
She needs a CGM.
She has a Libre 2, using it for a few months.
For whatever reason she was on insulin 50 units morning and after dinner. Now 40 units morning only and starts dropping in afternoon, eats dinner (about 35 carbs) and continues to drop (about 70-80).
Can't understand why...no pills, no insulin after 9am. She's 71yo
/ Diabetes #755
Every day is different. The difference between an item one day that sends you over 200, but only 150 the next can depend on the amount of that food as well as what is paired with it. Fiber will slow the absorption of the carbs into your system. It can also depend on if things are processed. Quick oats will spike your BG a lot more than rolled oats.
/ Diabetes
what do spikes of higher blood sugar do to you long term?
guessing this is a situation that usually gets worse not better without some
form of intervention
I am reminded of the negative impact repeated electrical outages can do on home electronics.
too many surges and spikes weaken and finally fail components
/ Diabetes #757
I believe the two of the impacts are oxidation of cholesterol which means plaque buildup and increases in your body's production of the hormone, insulin. That insulin will try to get your body to use the BG and produce more fat in the body. Without changes, you will get more and more insulin resistant. This is T2 diabetes. That high BG will cause inflammation in your body. This often shows up as joint aches.
I'm not certain what the mechanism is that causes people to lose sight and have limbs amputated is. Either way, you have an A1c above 5.5, take it serious! Prediabetes is just the start of diabetes. Your body is not healthy and you may not realize it. I thought joint aches was just getting older, but I was wrong. All joint aches disappeared as soon as I fixed things.
/ Diabetes
having all my joint aches disappear is only in my dreams with severe sddd but the aching hands and wrists, that might
be helped
I already take hydrocortisone daily and I think that helps with the inflammation somewhat.
/ Diabetes #759
be helped
A side effect of hydrocortisone is muscle aches. :)
I'm not sure what sddd is, but have you tried removing carbs? Obviously, carbs are not the cause of all problems for all people, but a few weeks with minimal carbs QUICKLY tells people whether it's an issue for them. I never would have stayed with this change if it wasn't a game changer for me. I remember getting slowly out of bed.
/ Diabetes #760
Below is what carb's are. What are you eating?
Carbohydrates, or carbs, are sugar molecules. Along with proteins and fats, carbohydrates are one of three main nutrients found in foods and drinks. Your body breaks down carbohydrates into glucose. Glucose, or blood sugar, is the main source of energy for your body's cells, tissues, and organs.
2005 Grady-White Boat w T/A Boat Trailer (A61574)
2005 Grady-White...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
2022 John Deere 7R 210 Tractor (A63111)
2022 John Deere 7R...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
