Best Approach for Whole House Wiring?
/ Best Approach for Whole House Wiring? #21
We just had the low voltage stuff done on our house that's under construction. I had them run cat 6 from the demarc where the fiber internet comes in to where I will put my router, to where the TV goes in the living room, to where I am going to mount long range wifi antennas to reach the gate and the shop, and where I'm going to put cameras. And the doorbell.
The wifi repeaters, doorbell and cameras could all be wifi but they need power. It's easier to run cat 6 and use PoE to power them than to run 120v.
The computers and everything else will be on wifi.
As far as dedicated circuits for appliances, how many outlets you need per room, etc, the electrical code covers that. Even if you're in an area with no inspections it would make sense to follow the code or at least use it as a guide.
/ Best Approach for Whole House Wiring? #22
220-221 whatever it takes.
/ Best Approach for Whole House Wiring? #23
I wired my home when we built it. I made all outlet circuits 12 ga, so no limit on what was plugged in. I also put a outlet bx in every room connected to 1/2 pvc conduit which terminated in the basement. Did this for both floors, all rooms. Over the years this has been very useful. Over the years we have had telephone, TV coax, CAT 5/6, fiber. Nice thing you can remove one technology and replace it with a new one.
paul
/ Best Approach for Whole House Wiring? #24
I would start the wiring project outside, with a whole-house generator. And some sore of enclosure for year-round protection and ease of maintenance. And then wire the house.
/ Best Approach for Whole House Wiring? #25
I didn't build this house, but I would have added more wall receptacles. I don't think one can have too many. One thing the person did that I do like is they used 12/2 wire throughout the house which I find great ! All 110V 20 amp circuits
/ Best Approach for Whole House Wiring? #26
Who knows what the future will bring, wireless works for many things but it is not the end all do all solution.
As far as I'm concerned it is hard to have too many outlet boxes, my preference is lots of boxes in the walls with conduit (flex) lines down to the basement or up into the attic. Then upgrades and changes are much easier to perform.
Also code in the minimal not the best in almost all areas.
/ Best Approach for Whole House Wiring? #27
I like the idea of empty conduits for potential later use. But, make your life even easier and put pull strings in them at the same time.
Doug in SW IA
/ Best Approach for Whole House Wiring? #28
Be sure to have outlets where you need them outside your house. My back porch has 4 outlets. I have them next to my garage doors, and at the corners of my house. I have them on my wall for my puppy yard, and I have them on a wall for a hot wire fence to keep the dogs from climbing over their fence.
Will you have any outdoor lighting? I have street lights on my driveway, and between my house and my barn. I also have street lights in my backyard so we can see the dogs at night and hopefully figure out why they are barking.
We also have dawn to dusk lights around the house. My wife really hates not being able to see outside at night and not being able to see anything. For me, it's nice to come home from work when it's dark out and see everything.
/ Best Approach for Whole House Wiring? #29
Doug in SW IA
I'm all for a few extra conduits, especially to/from areas that would be difficult to access post construction. If you don't know the intended use, I would use large radius sweeps rather than boxes where possible.
My $0.02 m I'm not sure it is worth pulling strings in advance. I use the baggie on a string trick with a shop vac. Takes about two seconds. I would rather pull a string or tape appropriate for the immediate project.
All the best,
Peter
/ Best Approach for Whole House Wiring? #30
Im an electrician, so i way overdid my house when i built it in 1996. Heck, no romex for me. Its all steel flex and metal boxes with MC light whips. All open shops and barn are emt pipe. I also ran twin cat5, and phone lines to all rooms. I no longer have land lines and never used any if the cat5, i even installed 2 Leviton recessed boxes with catv splitters and racks for phone and ethernet, with surge suppression, etc. none of it was used.
All wifi now. I did actually have to run a cat6 out to my generator for monitoring as it was having trouble dropping my wifi signal.
I have starlink ported thru a wifi/mesh router, and a separate mesh node in barn and shop. This gives me internet and phone out 400 feet from router and i have phone inside all my steel buildings. When we let landline drop, i had lost all phones inside shop until mesh came along.
All my outlets are 20 amps. All lighting 15 amps.
3 and 4way lighting all over the place. I can turn barn lights on from house. Have all exterior lighting run via astronomical timers that adjust for sun up and sundown. All turn off at 11 pm cause im not paranoid and like dark nights to see stars.
I use a system called YoLink to control things like turning on tractor engine heat, diesel truck heat, snow melt devices, security lighting and to monitor temps in refers and freezers and leak detectors. This system has saved my butt so many times alerting me to high temps in freezer and leaks under cabinets.
If wife and i are in town too late, i can turn on select house lights to make house look lived in. Random on and off.
Just added a yolink driveway alert because we missed package delivery too many times and had to reschedule. Dont miss them any longer.
I installed maybe 2x the needed electrical outlets as necessary…..but i dont regret it at all. Heck, my 3 car garage has 14 duplex outlets shared over 3 circuits. Ya, thats overkill.
I ran empty conduit out of all of my breaker boxes in house for future use, and have used them over the years. I installed a separate subpanel in master walk in closet behind door, another subpanel in utility room for some exterior circuits and a subpanel in basement. This was so all home runs didnt have to go all the way out to the garage main panel.
Subpanels save you alot of wasted wire runs.
My house is all propane heat, water heater, dryer and stovetop. So a 22kw backup generator powers entire house and barn. My shop has its own 10kw backup generator. Property has 400 amp service.
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59906)
2022 KAUFMAN 4X2 2...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
500BBL WHEELED...
2005 DRAGON 130 BBL STEEL VACUUM TRAILER (A60736)
2005 DRAGON 130...
