Danuser EP615
/ Danuser EP615 #1
Squirrel's242
South Central Texas
LS MT242
Has anyone had any experience with the Danuser EP615 FEL post hole auger? I'm ready to purchase a FEL post auger and this model is at the top of my list. I've also looked up Premier MD06PD and and Digga DDD and 1DSS in the similar gpm spec range. Are there any build and maintenance quality differences in post augers? Or are they all the same? Before I bought my tractor, twice I rented a Toolcat w/ a Blue Diamond auger to drill 11 of the 26 post already in the ground. Still have another 18 or so holes to get the fence wrapped up.
As for the flow on the MT242: Implement pump (gpm): 6.7. Steering pump (gpm): 5. Total flow (gpm): 11.7
/ Danuser EP615 #2
You will only get the implement flow of 6.7 GPM to run the PHD. Will operate just turn a little slower which usually is not a problem on a PHD.
/ Danuser EP615 #4
My Danhuser on my L4060 works very ok. Mostly just slow due to low flow tractor hydraulics. You can't really spin it & move the loader at the same time due to open center hydraulics. So the auger stalls when you move the loader. But those are universal tractor issues any hydraulic PHD will have. I 100% like my hydraulic loader mount over a 3pt PHD. Downforce & reverse are worth the fiddly slow hydraulics.
Don't get a bigger motor. Get one that's sized for the usable flow on your machine. Which is probably the small one.
/ Danuser EP615 #5
Also realize that the max torque shown is usually at 3500 psi, most tractors are less then 2500 psi so close to a third less torque
/ Danuser EP615
Well, enough researching, thinking, hem-hawing, and rethinking - I contacted my tractor dealer to get the EP615 ordered, w SSQA mount, hoses, Pioneer couplers and a 9" cast bit. He'll call when it's ready to be picked up.
The front gate entry to the property is only half done, with a make shift old gate hanging place that isn't deterring anything or anyone from coming in...apparently there's an invisible, 'sure, come on in' sign hanging out there :rolleyes: But, better to get to work while the temps are cooler than 105* and the ground is hopefully a little softer for digging. I'd love to get this fence further along.
/ Danuser EP615 #7
I’m still hem hawing. Like the sliding frame some offer to offset auger for better visibility with tractors.
/ Danuser EP615
I did consider that and why I ended up deciding against the offset was I was afraid that, generally, long term use of downforce would over time tweak the loader arms. I opted to go with a centerline mount. I thought once the arms/auger is up in the air, it allows for visibility of the bit tip at the ground. Plus with a spotter it helps to get in line and stay vertical.
Least that's what my thought process took me through, based on the type of soil layers I have dug through here so far in this fence build. This soil is very sandy the first 1-2', then it compacts in a hard sandstone then compact red clay. That combo caused us to switch from a one man auger and rock bar to renting a Bobcat Toolcat with the post hole auger to get 11 of the 27 posts in the ground now. The downforce I used to get some of those holes dug I thought I'd leverage myself up and tip over....weeeeeee!! o_O
/ Danuser EP615
The post auger is finally home. I took some time yesterday to get it mounted and hooked up. The major 'How do I' was routing the hoses. The 3rd function connections are oriented pointing straight forward on the loader arm. I was concerned the hoses would get pinched when the auger is all the way curled. I adjusted the connection bracket to angle slightly in and give some relief, and the auger end fittings have a 45" on them so I oriented those pointed out/forward, instead of back.
I got the auger bit mounted after a good wrestling match. I finally wised up and stood the bit upright against the wood rack and dropped the auger down into the bit cup and secured it. Thinking forward, I think some kind of bit stand would work wonders for dis/connecting.
I took the auger out for a spin, drilled a test hole. I was a little nervous but it worked fine. I did scare myself when I applied a little too much down force and lifted the front end off the ground. I recall doing that several times using the Toolcat. I don't like that feeling.
I've seen videos advising using the float setting on the loader to drill but I don't know. It seems like maintaining control of the downforce is ideal. Anyone have a preference or experience using it either way?
I do have a hose size question. The Danuser manual recommends 1/2" hoses. My dealer made me 3/8" hoses. How does that affect performance? Any issues I should keep an eye on for? The tractor's 3rd function hoses are also sized at 3/8". Out of curiosity, I roughly counted the rounds of the auger per 30/sec. It was about 16, multiplying ends up at 32rpm. On the test drive digging, it didn't seem too fast nor frustratingly slow. I'll see how it goes when actually in the harder dried packed red clay.
I did want to revisit what I said here:
I need to correct myself about being able to see the bit landing out in front of the tractor. I cannot. Even standing up. I'd still need and still use a spotter (especially to keep the bit plumb while digging). I can see it if I stand along side the tractor and operate the joystick but still need help watching the front to back plumbness.
The mounting plate does have the option to mount the auger head on the right side. It appears that I would be able to see the bit point on the ground if I do move it there. I do still think though that digging with the auger off-center isn't great for the loader arm symmetry/wear. I guess I won't know until I use it that way.
Anyway, I've got pics of anyone needs photos I can put them up. I appreciate yalls help, this is all brand new to me.
/ Danuser EP615 #10
if the 3rd function hoses are also 3/8" then the 3/8" auger hoses will have no affect.
This is the problem with most augers, really helps having an assistant.
/ Danuser EP615 #11
Digga’s halo option would help digging plumb from the operator seat without an assistant. Railroad crossties were a tight fit in a 1’ hole. Wish I had something like that years ago. Hillside drilling always a challenge.
/ Danuser EP615 #12
My SSQA PHD spins way slower than my 3pt ever did. If I recall 8gpm at 2,500psi is 18hp. So at best most CUTS are putting out 18hp to a 3rd function, likely a fair bit less with hydraulic losses. Your average CUT 3pt will be 20+. So you are loosing power & RPMs. I find the down pressure makes up for it in hole digging speed though. Not to mention ease of hitching.
/ Danuser EP615
That looks pretty cool, but really pricey. Probably for right now I better keep using free labor 🤪
/ Danuser EP615
Update, today put the auger to work. Knocked out two 4' deep holes for 10' gate entry posts in 20 minutes. My free spotter also paid dividends. Very happy with the first work performance of the auger. Will see what we get into tomorrow but today was a great first showing. This is light years better than the rigmarole of renting a piece of equipment. After the auger, swapped to forks to carry the poles to the entry and get them concreted in.
/ Danuser EP615 #15
Glad you are enjoying your new auger. I do not float the loader, I apply intermittent down pressure as required to keep it digging. I don't have the visibility issues you mention other than the fore /aft being difficult to estimate. My auger has a swinging level on the motor that gets me started, and I can stay straight from that point.
Never tried mounting the auger on the side because I don't like the idea of stressing the loader arms unevenly.
(2) UNUSED 7.5L-15 TIRES W/6 LUG RIMS (A62130)
(2) UNUSED 7.5L-15...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
2021 International HV507 4x4 Crew Cab Dump Truck (A61568)
2021 International...
New/Unused Solid Backing Plate (A61166)
New/Unused Solid...
