Thoughts on a PTO tiller & uses?
   / Thoughts on a PTO tiller & uses? #1
Fuddyduddy1952
Super Member
john deere
I have a 40hp Deere, FEL & backhoe, lots of attachments but I'm considering a PTO tiller.
One area I have, about an acre, is on about a 20 to 25 degree slope. I'd like to get it as level as I can, it's near woods and had lots of waist-high scrub pines and cedars which I used my 5ft bucket & tooth bar uprooting & piling downhill...edge of woods where it gets very steep. I tried bucket, backhoe and 7ft rear blade but nothing works well for leveling.
It seems like with a tiller I could loosen soil, then back blade work it downhill, etc. in passes. I'm guessing when finished I'd have about a 3ft drop-off at top, 3ft bank at bottom.
Area is a long rectangle.
If a tiller would work, what's a good brand? It would only get about 50 hrs use a year.
It also could be used for a small garden.
Another idea is would I be ahead just paying someone? I'm guessing an excavator would charge about what a tiller costs...but it would be better than if I did it.
One part possibly a for a 120'x60' riding ring, another planting Christmas trees.
Thanks.
   / Thoughts on a PTO tiller & uses? #2
I don’t think a tiller would work if you have very large roots in the soil; small roots yes. I had a Woods brand tiller for over 25 years and I bought it used from an equipment rental company. It never gave me any problems and I beat that thing on hard clay ground with small rocks. I think that any of the reputable implement companies would make good tillers. Be sure and get one a bit wider than your wheel track. Mine was a chain drive, but some companies like King Kutter offer gear drive models; probably more durable, but more costly to repair if you snap a gear tooth. Mine had a slip clutch driveline instead of a shear bolt and I think the slip clutch is better if you’re hitting rocks or roots.
   / Thoughts on a PTO tiller & uses? #4
Thanks.
I tilled a customers garden for 5 years that was on a 20 degree slope. It was extra work for me to keep the soil in the garden and not sliding down hill and creating a dead furrow on the uphill side.
So I think if you tilled driving only up hill, the soil will move down mostly on its own. To help force it downhill, move the steering wheel half a turn back & forth, forcing the tiller to wiggle back & forth.
Kinda like a woman swinging her money maker, as you watch her walk away.
A forward tine travel tiller would be best for this job....Any brand will do. They all will probably out live both of us.
   / Thoughts on a PTO tiller & uses? #5
A blade, straight or box, is the tool to "terrace". Box blades usually have ripper tines that work soil and roots.
A small box blade (loading considerations, soil is HEAVY!) is my choice.
BTDT!
BTDT!
As I was writing I thought about a box blade.
I wonder if that would be better than a tiller?
There are places on my land like a pasture that's not all that steep, but an area maybe 300ft long that drops 2ft then continues. So bush hogging I go straight downhill then if I don't lift deck it scalps. I'm thinking about tiller I could work that area then level with rear blade so pasture would all be even (15°-20° slope). Of course, seed area.
Picture is area I'd like level. I held camera level and I'd leave those large poplars but remove cedars beyond, now they're 6" at base.
I'm thinking with the 7ft backblade I wouldn't need a box blade. I know it doesn't have rippers but it's super heavy duty and adjustable every direction and hydraulic top link. For my purposes wouldn't a tiller be more useful? I could till high spots, then grade it smooth.
I tried bucket, then toothed bucket, etc. and it doesn't work well.
2011 BMW 328i (A56859)
2014 PETERBILT 579 MID-ROOF SLEEPER (A58214)
2014 PETERBILT 579...
DEUTZ MARATHON...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
2023 POLARIS 1000XP CREW RZR XP (A52708)
2023 POLARIS...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A52709)
2016 CATERPILLAR...
