BX23s rake attachment
/ BX23s rake attachment #1
rogerwrob
Member
ks
kubota
I am looking for a rake attachment for the end of the backhoe on my BX23s. Im not looking for 3 point hitch rake to pull behind but one to use like a claw at the end of the backhoe . I have found a couple but the dimensions for the pins are all over the place . These rakes are about 10 by 24 inch in size .Has anyone bought a rake for their Kubota that is working good for them? Thanks in advance , Roger
  • Screenshot 2025-03-05 at 12-36-37 Amazon.com Mini Excavator Rake Excavator Attachments Wide Ba...png
/ BX23s rake attachment #2
bxpanded.com makes backhoe attachments that'll fit; I've got a one-tooth claw from them (and a quick-attach) but I haven't ever seen a rake like thing for backhoe.
If you can find one you like, you could get a local welder to cut the ears off and set it up to match your backhoe.
Thanks. I have the BX expanded ripper and quick coupler all ready. i need a rake to help dig through a pile of mixed stone, branches. that may be a good option as far as order one on line and have the new ears welded on , thanks
It seems like there are not a lot of rakes for tractors like my Kubota . What I am finding is a search for Mini excavator rakes is a more productive way to go about finding them.
/ BX23s rake attachment #5
See if BExpanded can modify an appropriately sized rake from the mini ex world to fit the quick change setup if you buy it and send it to them.
If I buy on line I would just have the welding done locally.
/ BX23s rake attachment #7
That makes sense. If you already have the QuickOn setup, the local shop should be able to use that to adapt the rake of your choice.
I went on line to educate myself on this and found some good and some bad ideas for crazy machines lol. I am going to try and make a simple rake out of metal i have laying around. This is a pic of my first proto type. i will put tips on the ends if the unistrut to dig in a little.
