How does a NOCO battery charger "desulfate" the battery?
/ How does a NOCO battery charger "desulfate" the battery? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have 1, 3 and 5 amp NOCO battery chargers and on the 3 and 5 amp do not fully understand how the desulfate function works. Can anyone explain how this functions and if it auto-engages or I have to set some special way? The 1 amp does not have a desulfate mode.
/ How does a NOCO battery charger "desulfate" the battery? #2
Google can be your friend... ***The desulfation process is a 24-hour cycle during which the charger emits a high-voltage, high-frequency, low amperage pulse into the battery. This pulse is designed to knock crystalline sulfate deposits that have built up on the battery's lead plates, back into solution. Oct 12, 2022***
I have one and has kept the dual batteries in my Dodge diesel going for 5 years. Batteries are from NAPA.
/ How does a NOCO battery charger "desulfate" the battery? #3
yeah it like a recover or repair mode (same thing)... the 1 amp doesn't have it because its insufficient amps for it... you would used the desulfate mode when a battery is flat dead.
/ How does a NOCO battery charger "desulfate" the battery? #4
NOCO states otherwise
/ How does a NOCO battery charger "desulfate" the battery? #5
I'm not sure how they do it but it works for me. I have a Noco 10 amp with desulfator connected to my Genie aerial lift which is used as an elevator. The OEM battery costs over $500. When it finally died, I switched to a $125 NAPA deep cycle battery with a one year warranty. So far, It's lasted 6 years with the Noco.
/ How does a NOCO battery charger "desulfate" the battery? #7
Pro mariner chargers also have this function.
/ How does a NOCO battery charger "desulfate" the battery? #8
Every battery charger desulfates. It is how the acid is restored. Some have a pulse charging cycle that supposedly knocks off hard sulfation from the plates. Most independent studies have shown little benefit to such modes. Hard sulfation does not readily recombine and just ends up as dregs at the bottom of the battery.
/ How does a NOCO battery charger "desulfate" the battery? #9
I don't know technically how any of the desulfate cycles work. If anyone knows, I'd love to hear how it works.
Apparently some desulfators are different than others. For the last 15 years we've used BatteryMINDer type chargers just because they were the first I saw with a desulfate cycle & because it has worked for us.
Plus the charger has an optional high amp output powerful enough to charge a large 12 volt overnight. On our place we maintain about 18 large AGM batteries plus some spares, and replace two or three per year.
BatteryMINDer claims that they originated the desulfate cycle and that theirs is different enough to rate a patent. Whether that is true or not I have no idea. I've not looked up their patent and studied it so have no real knowledge what it does.
I do know from experience that if a battery is clear flat, it needs at least some charge from an old style "dumb" charger before the BatteryMINDer will take over and desulfate/charge it. But once it does, some of the "dead" batteries will actually charge up and hold a charge - so their desulfate must be doing something useful.
Interesting subject,
rScotty
this one as it I guess but the one Op's has doesn't has he mentioned it...
I just presumed the one amp didn't have desulfate but I guess it does.
/ How does a NOCO battery charger "desulfate" the battery? #11
My Honda charger has a automatic desulfate mode, it has three different lights, when you first plug it in if it’s hooked up correctly one green light and one yellow light come on, the yellow light stays on until it’s done with desulfurization then the yellow light goes off and the other green light comes on indicating the battery is fully charged. The yellow light usually goes off within one day but I have seen it stay on for 2 days if it’s been a long time since it’s been hooked up to desulfurization.
I am a firm believer in the benefits of desulfurization .
/ How does a NOCO battery charger "desulfate" the battery? #12
I have has a Schumacher automatic charger with that option. That option never worked for me.
/ How does a NOCO battery charger "desulfate" the battery? #13
First you have to understand how a lead acid battery works. Inside the battery is two different types of lead with sulfuric acid. Acid has excess electrons that the plates will access when a load is placed on the terminals attached to them (pos and neg). As electrons are drawn from the acid it chemically splits the sulfur from the water and the sulfur loosely coats lead plates. Thus as the battery gets discharged the acid is converted to water and when it is recharged it is restored as a acid.
Battery chargers put a voltage on the plates that allow electrons to force (desulfate) recombining the sulfur with water to create acid again. Overtime though the sulfur coating the lead plates can not be fully driven off and becomes hard. This does two things it reduces the active area of lead for electron transfer and it also weakens the acid. SG tests of the batteries acid strength corresponds to battery capacity.
/ How does a NOCO battery charger "desulfate" the battery? #14
I called Schumacher some years ago and they said all there modern electronic controlled chargers have it. Seems to work for me. I bet lots of chargers have that feature today.
/ How does a NOCO battery charger "desulfate" the battery? #16
About 3-4 years ago I bought el cheapo 12-24v charger for my boat 24v setup. It has repair function. I was skeptical about it, but since then I was able te bring to life 2 of my dead batteries, one of my friend 's and recently my neighbor 's. Unfortunately it doesn't have maintenance option. It does what it needs to do a d turns off.
Charger
/ How does a NOCO battery charger "desulfate" the battery? #17
All NOCO chargers have a desulfation feature. Some people confuse this with "repair mode" for the option to force a charge (I forget what they call it), which is a different thing.
/ How does a NOCO battery charger "desulfate" the battery? #18
is that right ? i also though it was the same thing ...
/ How does a NOCO battery charger "desulfate" the battery? #19
Yes. The desulfation stage is automatic on all of their chargers. It happens near the beginning of their charge cycle.
/ How does a NOCO battery charger "desulfate" the battery? #20
After some research it look like you are right but my confusion came in as some some repair mode or Recondition Mode has the Desulfation incorporated with it... but your right Desulfation is specifically for lead sulfate buildup as recover is a mode is a more general recovery process such as stratification...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
Orange County Sheriff (698) Title Brand: Police Year: 2018 Make: Ford Model: Explorer Vehicle Type: (A59231)
Orange County...
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
Rockport Mobile Command Center (A59230)
Rockport Mobile...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
