Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #24,721
Nice setup, there!
I average 10 full cords per winter, but our house is large, old, and mostly uninulated stone construction. We have 60 windows, more than half of which were installed in 1775. We have 14 exterior doors, some of them dating back as far as 1734. This place ain't exactly the picture of optimum efficiency. :D
The last two winters, we got off easy, just 6-7 full cords. I was actually beginning to tell myself we were more efficient than we had been in the past, but the reality is that we just experienced two very short and very warm winters. This year having been more typical, until this week's warm spell, we're ripping thru a good bit more wood.
We were all pretty sad when our old farmhouse burned around 1980. It was probably for the best though, as far as the heat energy consumption goes. It had likely been built around 1860. My great great great great grandfather homesteaded our farm in the 1830’s and lived in a log cabin for a few years. My dad remembers seeing some remains of that, but it was long gone when I was born.
Grandpa and grandma replaced that big old burned down farmhouse with a fairly well insulated 1200 square ft ranch house. While grandma was still living in that, my wife and I nailed an 800 sq ft, “3 room shack” apartment onto the back (also fairly well insulated). Grandma passed away 14 years ago.
Now we have a 2000 square ft L-shaped ranch that only takes an average of 6 face cords to heat. That’s a very manageable amount for me to make in my free time. I love wood heat and there’s no way I would live way up here, near the Canadian border, without it.
   / Tractors and wood! Show your pics #24,722
That's really cool. When I was a kid, there were also a lot of old homes originally homesteaded by my family, but all sold off after my grandparents' generation. Some had been handed down father to son, for more than 300 years in our family.
But these houses down here aren't built for Canadian winters! It's easy to build big and with poor insulation, when there's only one or two truly brutal months each year, versus your much longer winters. Many would settle for keeping just one or two rooms heated during our coldest months, as keeping the entire joint warm using fireplaces or old low-efficiency wood stoves must have been mighty tiring, and the duration was a much shorter fraction of the year than what you guys see.
The thing I've noticed about our northeast USA cities is that they can get mighty cold for a few weeks each year, but the duration of our very cold weather is much shorter than those up north.
   / Tractors and wood! Show your pics #24,723
Slice from a 20" white oak round. I don't think I've ever seen one shrink like this into a bowl shape before. Very dry but no cracks.
   / Tractors and wood! Show your pics #24,724
Good price comparatively. But I have no idea of quality. Looks kind of light but probably hard to tell. I have an Igland which is great but heavy. Wish it didn't weigh so much. That one sided bearing / spindle takes a lot of stress.
I will say Woodland Mills makes good stuff imo. I have a WM chipper with 200 hrs and no issues.
It looks very similar to the APM block I own (which has held up very well, after a simple modification I made to it). Te only difference I see right off the bat is that the APM block has a pipe or bushing around the pin/bolt the strap connects to, and the release trigger on the
APM Block Woodland Mills
   / Tractors and wood! Show your pics #24,725
Nice setup, there!
May be a pain to keep warm but your house sounds extraordinary.
If walls could talk kind of thing
   / Tractors and wood! Show your pics #24,726
With moving to the new place down by the shore, This is the first year in 60 that l have not skidded in firewood.
30 yrs as a logger then 30 more as a home owner.
There is a hole in my soul.
   / Tractors and wood! Show your pics #24,727
   / Tractors and wood! Show your pics #24,729
I don't think that I could lift that.
   / Tractors and wood! Show your pics #24,732
As you look at that picture the left few feet of it is hollow. My tractor is a JD2025r and if I can pick it up a Kubota L should be able to.
   / Tractors and wood! Show your pics #24,734
I cut some logs up into rounds today. This is about all my tractor will pick up.
Actually, thats a pretty good load for that size tractor no matter what the stem species is.
You must have quite the ballast out back.
Is this a grass cutter as well in the season?
   / Tractors and wood! Show your pics #24,736
Yes I have a 60” mid mount I mow with. I checked my pressure with a gauge and I was on the low side of spec. I bumped it up and am over spec now by a couple of hundred psi. I’m not sure how much weight is in my ballast box, 500 to 600 pounds probably plus I have rim guard in my tires that adds up to 300 pounds.
   / Tractors and wood! Show your pics #24,737
Split up about 10 of these poplar rounds today. I don't like poplar as firewood, most don't. But my morning wood has always been poplar, burns fast and hot and then is done. A good way to start the day
   / Tractors and wood! Show your pics #24,738
Well with winter coming to a end I wish I would've done more firewood then this. Although it should be good enough, I now have to switch to cedar post as the wife want me to built her a horse outdoor arena this summer.
the left stack need to be dried and the right side stack is dry already
   / Tractors and wood! Show your pics #24,740
I have a ton of Holly on my property, wife wants it gone. I have a 16lb splitting maul, which just bounced off the piece of Holly I was trying to split. Guess I will need to wait until I get a splitter, then again, I'm not sure if the Holly is worth trying to burn.
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
2014 Ford Fusion Passenger Car, 2.5L Engine - Only 90,875 Miles (A56438)
2014 Ford Fusion...
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
2014 Chevrolet Impala Sedan (A59231)
2014 Chevrolet...
