Lazy Way to Fix Cart Tire Hole too Big for Plug?
   / Lazy Way to Fix Cart Tire Hole too Big for Plug?
Still got air in the left rear, but the left front is questionable. What did this guy hit?
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #22
Maybe it was used in a scrap metal yard? A tube is the surest method of stopping all those leaks.
Follow the procedure so the tube doesn't get pinched during remounting.
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #23
another thread
I went with
TireJect Lawn Mower 5-in-1 Off-Road Tire Sealant - Flat Tire Protection Kit with Sealant Injector - Repair & Prevent Flat Tires (pack of 3 10oz packs plus deluxe tire stem remover, big syringe style injector that holds 5oz (with another small stem remover inside), 4 valve caps, 2 spare stems) $45@Walmart
It's held fine since mid-Sept.
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #24
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #25
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #26
I temporarily repair tires like the above quite regularly. I don't know about a bias ply tire but the repair lasts for about 10000km on a steel belted radial. The broken pieces of steel belt break off and migrate through the patch causing the plug to leak. But it works awesome to get you going in a pinch. You don't need to light the glue either. Just trim the plug flush with the tread and start driving.
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #28
Should work on a golf cart though unless that thing is really fast..
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #29
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #30
New/Unused 8in Bucket (A57454)
New/Unused 8in...
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
549 (A52708)
549 (A52708)
SINGLES TREES & HAYNES (A58374)
SINGLES TREES &...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
2015 AMERITRAIL MANIFOLD TRAILER (A58216)
2015 AMERITRAIL...
