deezler
Elite Member
- Joined
- Jan 30, 2012
- Messages
- 3,751
- Location
- Southeast MI
- Tractor
- Cub Cadet 7305, Kioti CK3510seh TLB
Think long term. I need to keep the amount of handling down to a minimum as I am in my late 60's. I will no longer stack wood over and over again or handle split wood multiple times. I used to load split wood into the Ranger or pickup, then stack in a pile, and then stack it into the Ranger or pickup to move to the garage, and stack it again....grr! Each piece stacked 4 times before putting it into the log carrier to the house.
My current plan:
How to make Portable Firewood Pallet Racks - YouTube
I use 5 cords a year so will need 15 units to store 1 year of wood. Each unit requires 11 sq ft of ground space. 165 sq ft of covered area. A 20x21x9 steel carport will cost $2000 installed. It will hold over two years of wood.
http://allsteelcarports.com/wp-content/uploads/2018/06/MI-Region-CARPORT.pdf
Wood will go from the splitter into the cut down pallet as it is split. These pallets will be moved to the carport for seasoning.
Stacking wood is the most useless activity in the process of using firewood, and it cannot be mechanized, so I am trying to minimize it.
Heck yeah Don. This is also nearly my exact plan. A metal carport seems to be about the cheapest way to get a durable roof over a large area. My loader is also fairly limited in lift capacity at the moment (having to clamp on forks over the bucket edge). A new Kioti 3510 with quick attach pallet forks would surely solve that, but gotta convince the wife first. Right now I use various pallets and wooden crates, under tarps or old plywood sheets for rain protection which doesn't always work. Lots of my firewood grew mold even as it was kept dry this summer - grrrr! But most of these pallets/crates I can't fill up all the way, or I can't pick them up with the forks. Probably can only lift about a 1/2 face cord right now - not good enough!
