2007 foton 404 knock
/ 2007 foton 404 knock #1
bobmed
2007 foton 404
I bought my tractor it sounds like rod knock idle and idling up. Anybody know what cost to fix. Or used engine for sale websites
/ 2007 foton 404 knock #2
Not to be snarky, just trying to put things in perspective. How familiar are you with diesel engines?
A lot of people that hear diesel engines for the first time think there is something wrong when it is actually just they way they work.
One of the first things that comes to mind is the injection pump timing. Usually a simple fix for an experienced mechanic but a bit more trial and error for us shade tree do it yourself types.
It would help us to better understand your question if you gave us more information.
How easily does it start?
At what temperatures?
Does the sound go away after it is warmed up?
What kind of smoke are you seeing from the exhaust, blue, black or white/grey?
How is the oil consumption?
When was the engine oil last changed?
When was the injection pump oil changed (assuming it has it's own sump)?
Does the noise get louder under heavy load?
As for engine prices I would suggest looking at some online dealers like Affordable or Circle G for parts, blocks or complete assemblies.
Paying someone to to do the work will vary wildly by location and competence of who you hire.
Where are you located (roughly)?
It's a hard knock. Very loud. Afraid it could trash engine. Somewhat familiar just not a desil mechanic
No smoke. Really. Sound like rod knock.
PEarlville mo
/ 2007 foton 404 knock #7
Yikes.
I'm not familiar with that particular tractor or engine. My first instinct would be to drain the oil and look for metal in the pan and open up the oil filter and look there too. Then probably drop the pan and see what the lower end looks like inside.
If you find the engine data tag you can do a more specific web search to look for used engines.
Depending on the condition of the tractor, you might be better off with a short block or complete assembly from one of the tractor dealers. At least you could get prices from them to use as a basis for your used search.
Best of luck.
/ 2007 foton 404 knock #8
A bad fuel injector can cause the engine to sound like a bad bearing.
Anyone know where can get rod bearing. Dropped pan its bearings. C490bt is engine I 2007 foton 404
Dropped pan definitely bearings anyone know where can get bearing. It's 2007 foton 404 with c490bt. Desil
Dropped pan definitely crank bearings anyone know where can get bearings its 2007 foton 404 with c490bt desil
/ 2007 foton 404 knock #12
Most rod bearings have their specifications printed or engraved on them, so take a close look at the ones you removed. Once you have the model number, you can search for it online or visit a local bearing shop—they should be able to help you find the exact replacement.
2022 EZ-GO ELITE...
New/Unused Wolverine Hydraulic Screening Bucket (A65583)
New/Unused...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
KIVEL PALLET FORK ATTACHMENT FOR MINI SKID STEER (A64553)
KIVEL PALLET FORK...
2001 WESTERN STAR  4900E (A65643)
2001 WESTERN STAR...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
