Will my 8'x8' shed blow over in the wind?
/ Will my 8'x8' shed blow over in the wind? #11
I've seen larger structures than this get flipped. Anchoring now will save you from aggravation and regret later. I've always built on posts 42" down and we've had horrendous winds at times but everything has stayed put
/ Will my 8'x8' shed blow over in the wind? #12
When I got the insurance check, I rebuilt the dog kennel by using 4" posts cemented into the ground all the way around, then framed the roof and put PLASTIC roofing on instead of tin. Never going to let that happen again.
Not sure what you mean by plastic roofing...are you referring to the corrugated stuff? Never had very good luck with that myself.
ISTM UV would weaken that roof rather quickly given that you're in the south where the sun is strong.
/ Will my 8'x8' shed blow over in the wind? #13
"ISTM UV would weaken that roof rather quickly given that you're in the south where the sun is strong." - Agree -
My ridge cap was the clear plastic and while it let in alot of sunlight it was only about 6 years old before it started to leak. My Amish neighbor that builds pole barns told me that they are great until they start leaking - generally about 5 years.
This shed is on skids. I planned to get four of the 24" screw-in earth anchors and hold down to the ends of the skids. It's pretty hard to pull one of the anchors out. What do you think?
/ Will my 8'x8' shed blow over in the wind? #15
Those are good - they can be tough to get in but they are pretty good. Anything you can do to hold it down is better than just trusting gravity to do it. Good luck with it
/ Will my 8'x8' shed blow over in the wind? #16
Here's what they have to do on Mt Washington in NH.
/ Will my 8'x8' shed blow over in the wind? #18
Yes, corrugated plastic. Reason being if it blows off it won't damage any other properties. So far it's baked in the summer sun for two years with no issues. We'll see....
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
2016 Volkswagen Tiguan SUV (A59231)
2016 Volkswagen...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
