1754 with sensor or control unit issue
   / 1754 with sensor or control unit issue #11
Worth shot before the dealer route. My LS did take holding it what felt like a long time, The other stuff is required, brake neutral and running,
More or less in order:
When I tried manual regen, I had the tractor in neutral and the parking brake engaged, which the "P" dash indicator confirmed.
I tried pressing the manual regen button several times in one second or so intervals. I tried holding the button for perhaps 4-5 seconds. Never nearly so long as 10. I will try that.
Thank you to all who have provided feedback!
I needed to check, because I did not recall the detailed list of instructions that @thclimer included. My manual is nothing as detailed. Here is the entire section on DPF manual regen, which has a completely different chapter designation amongst other things.
So no time like the present as the aphorism goes. It's dark and 35 F here, but I did the routine as before except I held the regen button down much longer. Somewhere around 7 seconds the engine revved up on its own and the "blowing" dash lamp went from flashing to solid. Regeneration is in progress. Thank you all who helped! Much appreciated.
   / 1754 with sensor or control unit issue #15
(y) (y) (y)
   / 1754 with sensor or control unit issue #16
Wow, that's ENCOURAGING!
Was the tractor up to operating temperature?
   / 1754 with sensor or control unit issue #18
Nice to learn that it worked for you!
The key seems to be in holding the Manual DPF button for an extended period of time "several seconds"....... I guess is more like 7-10 seconds.
   / 1754 with sensor or control unit issue #19
Like that on my LS, sure seems like a long timer in the ECM code. However it does keep you from entering that mode by accident.
   / 1754 with sensor or control unit issue #20
LOT LOCATIONS (A51219)
1041 (A50459)
1041 (A50459)
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
John Deere 270 Compact Wheel Loader Skid Steer (A50322)
John Deere 270...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
