Tractor in shop for 100 days
/ Tractor in shop for 100 days #1
hilltopdude
bobcat 753
I would appreciate any wisdom offered. I have a 2020 Workmaster75, it has been in the dealership since 10-2024.
They have not found the problem as of yet. I have contacted corperate and they are trying to help. problem is the dealership lost every expierenced tech on staff.
the tractor has been taken apart several times, and several parts have been replaced to no availe.
Has any one on here had the same or like situation and how did you resolve it.
I dont think that my tractor will ever be solid with all the things that were tried with out success.
The engine bay and dashboard have been opened up by the dealership account over 5 times.
The only tech at the dealership was hired and sent thru a two week class that lasted the entire month of Novemeber.
I bought this tractor when i retired from my day job thinking this would be the one the kids would have to get rid of in the auction when i'm gone..
Like i said the rep from cooperate jumped on the situation, but i am still getting reports of the dealership of waiting on a part, getting new codes for yet another system on the
machine.
/ Tractor in shop for 100 days #5
Did you buy it from the dealer? Did it come with a problem? Hrs? History?
BTW, what is the mechanical problem? Have you used the search function here on TBN??
There is a reasonable chance that someone else has had a similar problem with their NH.
Also, without knowing rough location and use it is hard or anyone to recommend a dealer.
One thing is surprising -Factory Training schools used to be common. But today, a dealer sending a new hire off to a class is almost as surprising as finding that factory classes still exist....if they do.
rScotty
I almost bought a NH Boomer once... Nice looking tractor.
/ Tractor in shop for 100 days #6
This. Request the machine be sent to another dealer; hopefully there is another NH dealer withing reasonable distance.
We don't know if this tractor is under warranty either. Either way, a second dealer to take this job upon themselves need to ensure that they will be paid fully for their efforts. If the first dealer cobbled everything up, dealer #1 should pay for that, not dealer #2. The regional service rep needs to be fully involved at this point. The rep would also know if dealer #1 had previous problems with service/warranty work.
/ Tractor in shop for 100 days #7
I misread OP's post, thinking the tractor was a 2024; I was presuming it was under warranty- but you're right, it may not be, and there is always the chance the work might not be covered anyhow.
Look into having it moved to another dealer who has the experience to fix it?
What’s the problem with it?
That's the problem. They can't determine the problem. It has changed 5 times
/ Tractor in shop for 100 days #12
Yet another thread where pertinent parts are left out..and qualified labor today is sadly lacking anyway. Why I stick with my Kubota dealer and any farm related items I buy from them. Been in business over 40 years and their service department is top notch.
/ Tractor in shop for 100 days #13
You sure helped him out.
/ Tractor in shop for 100 days #15
I guess the answer to your first post is yes and depending on the problem the frustration was understandable or not.
We’re trying to help you. Obviously you brought the tractor to 5 dealerships due to some negative or undesirable operation or appearance, ie “problem”.
Q: What is the problem or why did you bring the tractor to the first dealership?
A: Your answer could be anything (?).
A- I have to much money and I want to find a problem before it begins (The dealerships are doing their job).
B- The tractor has 4 tires and makes a loud rumbling sound when I turn the ignition key to start (Dealerships might be incompetent or ripping you off).
C- Etcetera, atcetra, etc? :p
/ Tractor in shop for 100 days #17
When the info is vague and the trouble is only listed as ‘dealer can’t find issue since May 202X’, I assume there is WAY more to this story.
Every reply asked for more info but op won’t post any info.
Methinks he has broke something and wants it fixed free???
/ Tractor in shop for 100 days #19
machine.
I’m not sure, it has been a long time and my memory may not be exact, but maybe this will help you.
When I was turning wrenches back in the ‘80’s many vehicles came in with hard and intermittent electronic issues. Some of the hard issues we confidently knew exactly what it was and the repair completion was easy (even though it could involve major disassembly) but it also depended if the dealership had the part in stock.
Some hard and intermittent electronic issues were not so easy to correct. Sometimes we had a bad electronic part that failed when it became hot, those parts were coveted and held on to by the technician, (if warranty/customer didn’t require the part returned) because that part could be used in future diagnostics.
Most if not all electronic parts had an isolated diagnostic procedure that indicated/pass fail parameter with a % allowance in resistance or voltage. When the book/procedure said the part was out of parameter (and bad) it was supposed to be replaced, BUT replacement did not guarantee the problems was solved because the ECU depended on all inputs and some of those inputs were dependent on other inputs that might be near the fail parameter.
This made for a difficult repair because the dealership usually did not stock the part, the part had to be purchased and could not be returned, the customer had to wait, the mechanic had to clear his bay, and the customer was not always assured the purchase of the part would correct the issue.
At that time, the same challenges existed with some diagnostic machines that failed to progress the diagnostic procedure until the suspected failed part is replaced (repeat scenario). Unless the failed electronic part was systemically repeated across the brand the repair typically required straight time and a lot of it.
Unless you have a shop with well paid technicians on salary, straight time (not flat rate) was not welcomed by the technician.
We had one vehicle that would accelerate without warning and the diagnostic machine was all over the place in terms of intermittent faults and when those parts were isolated and tested some parts passed and failed, but the replacement parts NEVER corrected the uncontrolled acceleration issue. Finally, the luxury car was shipped to headquarters and a team of engineers worked on it to diagnose the problem. Months later we found out the wiring harness was faulty and was creating make break and high resistance connections. The engineers replaced the wiring harness and the problem was solved. I don’t know if the customer got a new car, but warranty paid for all that work including the earlier time for the technician. But if a vehicle was out of warranty the customer was expected to pay for all the parts that were replaced that did not solve the problem.
This is one reason I steer clear of equipment and vehicles that rely heavily on electronics, but you really cannot get away with that now.
Thanks for your time, I hope this helps.
/ Tractor in shop for 100 days #20
machine.
Just one more opinion for what it's worth.
What I have for you is NOT what you want to hear. Considering the complaints I've heard, read, and seen concerning the 2016 and up Workmaster line, my advice is this. Go back to the sales department and see what sort of deal you can work out to trade it off for some other model. (NOT another Workmaster) A 2015 or older would be much better all the way around, or just about ANYTHING in that size range. The newer Workmasters are a total POS. Even if/when they get past the current problem, there will be more down the road. Plus the fact they are so poorly engineered that even general operation is always going to be less than ideal.
832799 (A61166)
832799 (A61166)
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
DEUTZ MARATHON...
2020 Volvo L60H Articulated Wheel Loader (A61567)
2020 Volvo L60H...
2025 Unused SDLGC80 Electric Golf Cart (A60352)
2025 Unused...
