Can the hydraulic system get air locked after a fluid change
   / Can the hydraulic system get air locked after a fluid change
I'm still working on this problem ,just had to leave it for a couple days. I appreciate all the help! Looking at the hst trouble shooting one of the first things that day to check is the input shaft. Should it be turning when tractor is at idle and in gear? Thanks again the shaft isn't turning
   / Can the hydraulic system get air locked after a fluid change #22
If that is the condition under which the tractor should move then yes the input shaft should be turning.
   / Can the hydraulic system get air locked after a fluid change #23
On a hydrostatic tractor, as long as the engine is running, input should be turning.
Input turns when forward or reverse is applied at foot pedal otherwise not moving. Now what?
The input shaft only turns when foot pedal is pushed, forward or reverse.
   / Can the hydraulic system get air locked after a fluid change #26
Lets take a step back for a better understanding.
1. Is the pump still whining?
2. Does the tractor move now with authority as it used to?
3. Did you do any of the recommendations given within this thread and if so, which ones?
   / Can the hydraulic system get air locked after a fluid change #27
I had trouble with the first hydraulic oil change on my Ford 1700. 3-point became jerky. Took about 15 minuets to work all the entrapped air out of the system.
I tried forcing air in thru filler tube. Raised rear wheels and ran in forward and reverse. I then tried it on the ground and it will travel as it should for a short distance then stop. If I am on a down hill slope it rolls along as if I'm in neutral. Pushing pedal back and forth it will engage again for a short distance. The whining noise is only as it engages and not so much when traveling. Found 2 small leaks , 1 or 2 drops now and then but it has done that for a long time before this trouble started.Thanks I appreciate all the help.
   / Can the hydraulic system get air locked after a fluid change #29
You either still have entrained air in the system or your pump is faulty.
In your shoes, my last ditch effort would do the entire drain process again and this time fill very slowly.
If you’re certain of hydraulic fluid amount capacity, pour it in smoothly and re-mount your filters. The equivalent size tractor to yours of what we sell, takes 9 gallons. I am un familiar of what your 2610 takes.
Additional air was not going to do anything for you.
It is not a closed system such as a cars coolant system operating at relatively low pressures as opposed to a system operating at 2500# or so.
If you refill your tractor properly and there are no intake leaks and it is still doing what it’s doing, I’m afraid your pump is shot.
As to the leaks you report, are they indeed hydraulic oil leaks? Unless you have hydraulic connection compromised o rings, hydraulic leaks are of tremendous pressure and would usually squirt out in such fineness, you can barely see them but will easily cut into your skin causing a toxicity that needs tending to immediately.
Test those with a piece of cardboard.
The kind of leaks I’m talking about are on the intake side of the system that could keep causing entrained air.
Ok thanks a lot. I'll drain and start again with fingers crossed.
2015 Haulotte 5533A (A53316)
2015 Haulotte...
ALLMAND NIGHT-LIGHT PRO II 4 BULB LIGHT PLANT (A52706)
ALLMAND...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
THUMB ATTACHMENT FOR MINI-EX (A55745)
THUMB ATTACHMENT...
30006 (A53424)
30006 (A53424)
Butterfly Artwork (A55758)
Butterfly Artwork...
