Non synthetic trans oil
/ Non synthetic trans oil #1
Thegrovefarm
Midland, va
Mf TO35, MF253,jD A
Can someone provide me with a direct replacement for Massey Ferguson Permatran non synthetic non synthetic blend transmission fluid? I do not like to mix synthetic/non synthetic fluids.
All the product I can find that is labeled Permatran appears to be synthetic or a synthetic blend. I am using this in a MF 253 four wheel drive. UK mfgd.
Any help greatly appreciated.
Knots
/ Non synthetic trans oil #2
Take a look at chevron THF 1000
/ Non synthetic trans oil #4
Knots
You can mix it with no issues. Buy the Permatran syn, you wont rebret it.
If the pail has a Massey Ferguson spec such as M1135, and or M1139
and that is what the owners manual calls for are you good to go? There is a huge number of specs on the pail.
J20C seems to be fairly common and I guess is compatible with the MF numbers.
Can you tell me the difference between Super Universal Tractor oil and Universal Tractor oil. My manual calls for Super Universal Tractor oil with the above MF specs.
Thanks for your thoughts.
Knots
/ Non synthetic trans oil #6
Knots
Super oil can be used as engine oil as well as tranny, wet clutch, wet brakes, etc.
Universal is mainly for hydraulic parts and drive train of a tractor.
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
Giyi PG72 QA 72" Grapple (A60463)
Giyi PG72 QA 72"...
2013 PETERBILT 389 SLEEPER (INOPERABLE) (A60736)
2013 PETERBILT 389...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
2025 AGT Industrial MX-MRW14 (A60463)
2025 AGT...
