YT359 Specs
/ YT359 Specs #1
Jaybr
Gold Member
Cumberland, VA
Yanmar YT359
There was some info posted in another thread stating that the YT359 posted weights included the FEL and ballast in the tires. I guess the logic on that assumption was the listed weight says it includes fluid, and all of them come with FEL and ballast. There was some back and forth in the thread and I didn't want to continue to pollute that thread so posting this one.
I have a new YT359C and really wanted a solid answer on this since eventually I'll need to tow it. I reached out to Yanmar and verified that the published weight does not include ballast or FEL.
In my case the tractor weight:
Tractor - 4442 lbs
Ballast - 1100 lbs
Loader w/bucket - 1096 lbs
Total - 6638 lbs
The listed width of the tractor is 71.7", that is with the wheels in the narrowest position, they can be moved 7.7" wider putting the overall width at 78.8"
Hope this helps clarify a few things for anyone looking at the Yanmar YT3
/ YT359 Specs #3
That's a nice tractor, period.
/ YT359 Specs #4
Tractor - 4442 lbs
Ballast - 1100 lbs
Total - 6638 lbs
For comparison JD 5055E ,(JD’s lightest series)
Tractor 7054 lbs
Ballast 1100 lbs
Loader 1994 lbs
Total 10148 lbs
Deere is 52.8% heavier, that’s very substantial . Once again I like Yanmar’s but wanted to point out facts.
/ YT359 Specs
Tractor 7054 lbs
Ballast 1100 lbs
Loader 1994 lbs
Total 10148 lbs
Not disputing the weight of the JD, but you're comparing a compact tractor to a utility.
I don't think the Yanmar is light when you compare it to others in the same class.
Personally, the weight of the Yanmar is pushing the limits of my truck if/when I need to tow it, and I don't want a bigger truck.
Tractor + Implement + Trailer and your pushing 11k or more.
/ YT359 Specs #6
That was a big problem for me, too much ballast liquid. So I worked on draining much of it out with the rear wheels in the position where the valve stem was centered, all the way down. Drained fluid until it reached below the valve stem level then added air. Good to go, no problems since even with full manure fork full of stockpiled bedding straw and sheep manure from the covered feeding area.
/ YT359 Specs #7
Tractor 7054 lbs
Ballast 1100 lbs
Loader 1994 lbs
Total 10148 lbs
That's apples and bowling balls; compare it to a 4 series, Deere's largest compact utility tractor.
/ YT359 Specs
I'm estimating the ballast weight with the assumption that the dealer followed the recommendation in the owners manual, which is fill to 75% which is 550 lbs
2015 Kia Sedona Van (A61569)
2015 Kia Sedona...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61568)
2022 Mac Trailers...
1999 John Deere 7810 (A60462)
1999 John Deere...
2013 BMW 750i Sedan (A61569)
2013 BMW 750i...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
Ratchet Straps (A61569)
Ratchet Straps...
