Winch on trailer deck. Yea or nae?
/ Winch on trailer deck. Yea or nae? #1
Jeepnford
Gold Member
NE Missouri
Case DX35
I have a winch on my trailer with a receiver mount. It's great until you have to install the winch on the trailer. It's gained weight in the last twenty-five years. I have a tongue box which I want to keep using for tie downs. I'm thinking about putting a narrow box on the front of the trailer deck to put the winch in, so more permanent. The obvious problem with that is losing a foot or so of deck length. Has anyone mounted a winch that way and regretted it? My trailer is 24 ft. long.
/ Winch on trailer deck. Yea or nae? #2
Diamond C has a really nice flip up winch mount. Maybe you can borrow the design.
/ Winch on trailer deck. Yea or nae? #3
No room to move your tongue box forward a bit so you can mount your winch just in front of the bed?
If not, is there a way to mount your winch so that it is easily removable in case you need the full deck (ideally with no tools required)?
I've seen two custom installations. I wish I had pictures of them. One had the winch permanently mounted below the deck with a pulley redirecting the cable up above at the front of the bed. The other had the winch mounted below the deck in a box that could flip up, putting the winch above the deck when needed. I'd be a bit worried about either of these two options if it made the winch hang down too low under the deck: too much chance of damaging it if you found yourself on rough or uneven terrain (even backing out of some driveways might be a problem.)
EDIT: Eric posted while I was typing. I'm betting that Diamond C was the one I saw that flipped up.
The tongue box was "built in" I guess you would call it. Its angles formed and then welded to the trailer tongue and front rail and they kind of hold it all together. If needed I could cut it loose and move it a little but that's a last resort.
/ Winch on trailer deck. Yea or nae? #5
What about putting in the box with roller fairlead attached to the box with cable feed thru. Then fit a foam plug to fill hole. This way, the winch is kept out of the elements. Just a thought that I'm thinking of doing with mine.
I want to put winch in a box but am trying to keep the existing box for straps, etc. I would also like to leave everything needed on the trailer in place of keeping it in shop and having to gather it all up when needed. While typing this I thought a recessed strap box might be an idea, then put winch in tongue box.
/ Winch on trailer deck. Yea or nae? #7
I wanted a winch on my equipment trailer for winching up cars. Untill i bought a car with a bad engine, for body parts. It turned out to be a thrown rod and it couldnt make it up the ramps. I threw out two ratchet straps and pulled over the trailer with the car after uncoupling. That worked so nice that i never bothered about a winch again. In 8 years i did this trick 2 times now, so i dont really need a winch often.
/ Winch on trailer deck. Yea or nae? #8
Mounted a 12K Harbor Freight Badland winch on the front of my goose neck and I use it all the time. Have 3 Group 31 batteries mounted in the tray under the goose neck and I charge them with the harness that power's the trailer lights. The winch batteries also power the breakaway brake system.
/ Winch on trailer deck. Yea or nae? #9
My car trailer has a flat winch plate just in front of the main deck with a basket underneath. I didn't want to mount a winch permanently because the trailer stayed at a friends with more space, so I made a hitch receiver and mounted that to the winch plate. I use a Harbor Freight 12k Badlands mounted in a receiver mount and drop the battery in the basket below.
Mine is on a receiver hitch now. The older I get, the heavier it gets. Where I am, the risk of theft is relatively low, I might just leave it as-is and put a cover on it since it has synthetic rope.
/ Winch on trailer deck. Yea or nae? #11
I hear you, I probably should not have gotten such a large winch, it's overkill. We're in the process of moving to the country where I will keep my trailers at home and crime is very low. I may just mount the winch to the trailer at some point.
2018 Ford Taurus Sedan (A61569)
2018 Ford Taurus...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
2020 CATERPILLAR 304E2 CR EXCAVATOR (A62129)
2020 CATERPILLAR...
2008 FORD F-550XL SUPER DUTY INSULATED BUCKET TRK (A62130)
2008 FORD F-550XL...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A61307)
2021 Unverferth...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR2CJ453403 (A61165)
2012 International...
