Landscape Rake for Manure Collection
/ Landscape Rake for Manure Collection #1
Veteran Farmer
Kioti CK4020SEH
Does anyone have experience using a landscape rake in a pasture to collect horse manure?
I have struggled keeping up with collecting the manure of our horses, who are pastured 24/7, and am considering purchasing a landscape rake with gauge wheel. I figure the rake itself can be used for multiple purposes, leveling gardens, finishing touches on driveway touch-ups, ....
I am not sure of the following though:
1) will a rake pick up a large portion of manure effectively from a pasture (with short grass)?
2) Does manure need to be fresh? Still in large clumps or will stepped on manure and/or poultry scratched manure also get raked fairly well?
3) How critical is a gauge wheel for this task? It seems essential to me but I have never used one. The other tasks I don't think require the wheel but the pasture raking is the primary function that I need it for.
I am not expecting 100% collection of the manure but I do need to collect it for use elsewhere on the farm. Hand collection is surely more effective but I've got too large an area to cover.
I do understand that I can harrow it to spread it around so it does not need to be collected but I need the manure elsewhere, that was a primary reason to get the horses
/ Landscape Rake for Manure Collection #2
My experience is with cow paddies, which may be apples to oranges... the rake works like a harrow, it spread it around.
It does work nicely on the driveway!! Don't know about wheels, don't have any attached but I do have all the parts, just need time to build them.
/ Landscape Rake for Manure Collection #3
I'm thinking the rake would serve to break up the manure and spread it around more than gathering it. Also it should have some moisture to breakup, Maybe rake old manure after a rain ?
/ Landscape Rake for Manure Collection #4
Are you trying to windrow the horse apples or drag them a significant distance to create a pile?
/ Landscape Rake for Manure Collection #5
This definitely works. Sht Happens, Sht burns, and Sht now flies. Don't use max rpm on the pto. Makes nice windrows from multiple passes, then a pass with a bucket. I suspect that a traveling grain elevator (with paddles) could make a neat pick-up device going into a trailing gravity wagon after its windrowed....
/ Landscape Rake for Manure Collection #6
I will say this, if you purchase a landscape rake, be careful of what you get, they are not built equally and some are only good for very light loads to be put on them intended to be used with a smaller light weight machine, otherwise they will twist like a pretzel if a decent load is put on them.
Good luck. :)
Doesn't matter to me as long as it reduces the manure labor time to clean up. I envision raking straight into a pile, lifting rake and beginning again, not a long distance just long enough to have a decent pile, then I can scoot around picking up the piles.
That is what I was worried about, just harrowing instead of collecting, thx!
/ Landscape Rake for Manure Collection #9
Not sure if you could lengthen the top link enough to make a landscape rake work like an old hay dump rake. I suspect that trying to move the apples very far will turn them into dust but have no actual proof of that theory.
/ Landscape Rake for Manure Collection #10
I don’t want to collect the manure I want to break the clumps up and scatter it.
So I’m thinking of getting one to breakup the manure.
I’m thinking of turning the tines rearward like for pushing going in reverse sine most have the ability to reverse the tines.
However, I would pull it forward with the tines rearward in order to breakup the manure clumps.
/ Landscape Rake for Manure Collection #11
Mine seem to concentrate their business in one spot. I use a 4' chain harrow from TSC behind the Mule to drag turnouts, helps to spread it out and break it up. I drag it with the tines down and folding back so it doesn't tear out the grass. Really heavy areas I pick up with the bucket and dump over the fence into a wooded pasture for the wild hogs to play with. Then I bring in sandy loam soil to fill the area back in, especially where they like to roll.
/ Landscape Rake for Manure Collection #12
I'm pretty sure it'll just spread it like a harrow would. When we did boarding I use to drag the paddocks but got fed up with the carpet of poop it could leave behind so we bought a 'poover'! Greystone pasture vacuum I think is it's correct title. I tow it behind an ATV. For 2 horses in a 1 acre paddock I poover once a week, filling the larger one they offer. When we had 16 horses here I did about an hour a day keeping multiple fields clean. We've had ours for 5 years now, still going strong. Very easy to use, does a great job.
/ Landscape Rake for Manure Collection #13
We have a chain harrow 12’ wide (two six ft sections) but it is a pain to deal with when not using it.
/ Landscape Rake for Manure Collection #14
Great tip, thanks. Showed the videos to my wife, said to order it so I ordered their largest model. They offer 6 months no interest.
/ Landscape Rake for Manure Collection #15
I’m not understanding the reason why for removing the fertilizer the animals produce and then putting down a commercial fertilizer.
I know horse manure isn’t great fertilizer but it’s something. If the clumps are broken up the parasites are not an issue.
/ Landscape Rake for Manure Collection #16
I remove it, let it rot down, then spread it on my hay fields. Sometimes it just gets too concentrated in certain areas, and during dry periods, it hangs around for ages just building up. Our annual fecal worm counts are very very low.
/ Landscape Rake for Manure Collection #17
We have 3 horses. The stables has 4 12'X12' stalls on the east side with dutch doors. Each horse has their own stall with a turnout, separated by fence from the other horses. They tend to walk outside and poop in the same spot so it builds up there, especially in the center turnout which is narrow close to the stables. It has gotten 6" or so deep before I have gone in there and cleaned it out. It kills all the grass in that area, plus is a breeding area for flies.
/ Landscape Rake for Manure Collection #18
Our landscape rake with gauge wheels works sort of OK in a dry paddock, corral, or round pen - but not in a grass field. It really doesn't work at all for what you are describing. Sorry.... back to the pitchfork..
rScotty
/ Landscape Rake for Manure Collection #19
rScotty
Do you this it would work to just breakup manure clumps if it was reversed and pulled forward in a pasture?
I think a buddy has a landscape rake, I may try borrowing it to do a test run before buying one.
2012 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61572)
2012 Gehl DL11-55...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
2019 John Deere 4044M (A62177)
2019 John Deere...
2016 Ram ProMaster 2500 Cargo Van (A61573)
2016 Ram ProMaster...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
