best landplane
/ best landplane #21
Just my opinion and that of the Goodyear research facility in Texas, the Road Boss is the best simplest unit made. (y)(y)
I bought a Road Boss C8 at the end of last year to redo 2 miles of road on my property. It works very well, but I think I need to get my act together and order a top and tilt kit from you to make it even better.
/ best landplane #22
Top and tilt is a game changer (y) Once you do this you will wonder why you didn't do it sooner!
/ best landplane #23
$1893 for a complete set with the slot & guide float feature in the side link clevis shipped to you.
Currently at a 10 week lead time.
/ best landplane #24
I wouldn't think it'd be hard to establish some kind of hybrid box blade and land plane.
Perhaps a simple backing plate bolted on the rear of a land plane to hold more material?
I stare much at both of these things we have on the grounds of the tractor place I work at and even though
Ive suggested to both of them to marry, they have not taken the lead to make any kind of hybrid babies in the overnight hours
when neither man nor beast (well except for the coyotes now and again) dares to roam in the realms of the netherland.
/ best landplane #25
Gordon Gould is a member here and he has a pivoting tailgate on his.
I have all the parts made for my 7 foot LPGS, just no time to get everything together and get it completed. 😞 Should be able to move about 4 yards of material each pass with it once completed. 😎
/ best landplane #26
Sounds interesting.
Perhaps he’ll afford a pic.
/ best landplane #27
/ best landplane #28
My homemade LPGS uses 4x7x1/2" angle iron to hold the blades. Due to that, there is quite a bit of flat area for dirt to build up on, and once it builds up, it can pile up enough that my JD2555 won't pick it up. Now granted, the LPGS is already pretty heavy by itself, but they JD isn't a toy either.
I originally considered a rear gate opened by a cylinder, and maybe a couple trailing wheels to really stretch this thing out, but in reality, it works fine for what I use it for, so I just leave well enough alone.
I have a 6' boxblade that won't carry as much dirt as the 7' lpgs. I don't remember the last time I used the boxblade due to that.
David from jax
/ best landplane #29
4 cubic yards?
/ best landplane #31
I was thinking the same thing.
Depends on the material and how big a tractor he uses.. 4 cubic yards of loam weighs about 12,000 lbs. Sand is less than that by a little over a thousand lbs as moisture content is mitigated. Also this weight is being dragged and not lifted so at any given time, material is lost and gathered which makes the weight fluctuate.
The lightest material being loose top soil but 4 yds of that is still approaching 9000lbs but an 8000lb tractor should be able to manage that.
Snow on the other hand approaches around 7000lbs. Dry clay is about 3000 lbs less than loam for 4 yds give or take.
The gathering blade on a Cat D 11 is purported to carry over 50 yds of material at any given time.
Now that's a lotta weight.
/ best landplane #32
My LPGS is 7' wide between sides, 8' long and 22" tall. The tractor without a 3pt implement is over 12,000lbs.
You can see that material has been over the two support bars. This is with the material being with an ideal moisture content. When it has been wetter or with grass mixed in, it has without a tail gate pulled the implement full of material.
For me, this has worked very well at evening out (moving high areas into lower areas) acreage up to about 5 acres in size. As has been previously mentioned by sandman2234, the LPGS moves more material than a box blade (my BB happens to be rated at 1 CY) without a tailgate.
So yes, 4 CY with a tailgate and the LPGS is by far more than a one-trick pony implement. ;)
2022 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2022 KENWORTH T680...
JOHN DEERE LV4115 TRACTOR (A63276)
JOHN DEERE LV4115...
2012 International WorkStar 7500 Gallbreath T/A Rolloff Truck (A64194)
2012 International...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
2021 Ford Explorer SUV (A64557)
2021 Ford Explorer...
