Real estate General topic
/ Real estate General topic #661
I remember driving down to the Keys through Homestead after it got hit by a hurricane.
Almost every house was damaged, they said 25,000 homes, and looking at the spread of damage it was easy to believe.
LA is big and the damage is significant based on the areas and the fire maps.
A count of 12,000 buildings so far, and yes , who knows what is a building, could be a shed.
But it's still a large swath in 3 different areas with multiple fires.
And it's not over yet.
This summer was one of our driest, even without wind , 3 fires took off.
Luckily all three were put out before they spread, and mostly fields and crops damaged.
We are pretty spread out here allowing the fireman to form breaks and get in front of the fires.
We had a fire in town and one down the block, both building fires and put out quickly.
One, a garage was completely destroyed, another at a hotel was limited by new construction being to code and quick response by 3 fire teams.
We had an arsonist , who finally got caught trying to torch a local bar. She had already destroyed 3 houses (one of them twice). No motive, just nuts.
Not much the fire dept could do once they took hold.
So trick is to have good fire alarms and have central monitoring.
The three houses did not have this and the people were not home when she set the fires, so called in by passing motorists, too late for FD to do much except put them out.
LA catches fire every year, some years they have fires big enough to jump multilane highways.
Talk about high risk and no one has done anything to stop the spread.
They could:
Clear brush - not allowed
Use tile or cement roofs - no one wants to spend and gov won't enforce.
Have local water tanks filled from runoff - They have said this will happen so may times...
Have min distance between houses or build less houses - but everyone with $$$ wants to live there.
Last time I was in LA (August) they were building up on most of the hills outside the city, the ones that are bare of trees due to fires in the early 1900's and the ones that are known to become mud slides on any big rains.
insanity.
So, I dont know how insurance might work with that; but I've heard from others in FLa, we get our letter "replace or provide inspection of roof, or insurance is canceled". Owner puts perm metal roof on, and boom, rates go Up. Even though the roof is more storm resistant.... (more fire resistant too)
I would be in favor of insurance offering discounts to people who remove trees near the home (that applies to storms, fires, ice storms, and general tree damage), but they never seem to offer a carrot, just a stick.
/ Real estate General topic #663
I'm just glad we're all experts here and can pass judgement on the professionals!
It would not be the first time professionals were wrong…
It also comes down to allocating resources… your home may be your priority but may not be to the professionals in a sea of thousands of priority homes.
The Doc and his son credited with saving several beach front homes did have an escape plan… either by way of the sandy beach or by sea on paddle boards…
Another guy was on the radio protecting his home and as a professional scuba diver his back up plan was to lay low in his swimming pool with cache of full air tanks.
/ Real estate General topic #664
You can't really make that statement. Conditions varied by neighborhood, one having access to power and water while another did not. Others found the line of fire approaching their home at a time of day or week when winds were at their worst, versus another facing that condition at a more favorable time with lower winds or those blowing in a favorable direction.
Weren't the winds blowing something like 40 - 60 mph one day? No one is fighting a wildfire back with DIY equipment, under those conditions.
There's also the simple fact that some are more mechanically capable than others. An engineer, plumber, or mechanic is going to have a better chance at saving their house than the average chiropractor, psychologist, or illustrator.
Surely some could have been saved that were lost. But "all the homes that were lost"? C'mon...
A brain surgeon did just this and saved several homes acknowledge as such by the pros…
In short they kept putting out hotspots…
I admitted I'm not an expert on the environment and specifics of the fires out there. Yes, we get wild fires every year here in FLa, in the dry spring, and if we have a dry summer, combined with a couple months of no rain from spring, it can getting pretty bad, but its not the wind driven stuff.
I do know for a fire, you need fuel, but you also can't just have gravel everywhere, either. I would think planned off peak controlled fires would be a useful tool out there too, but again, I admit that I don't know.
I am pretty familiar with hurricanes, and that
We also sometimes have had fires that burn for months and months, when they get down to the peat in the Prarie bottoms, and they smolder and smoke for 4 or 5 months, and randomly pop back up.
/ Real estate General topic #667
For the fires in LA, the houses were the fuel. Once a few houses catch fire, with the strong wind, the fire is self-perpetuating until it runs out of houses. This has happened many times in the last decade: Paradise CA, outside Denver, Santa Rosa, Redding, Southern Oregon are just the ones I can think of off the top of my head. Some started in wildlands near houses and then moved into the suburbs but some started in the suburbs.
Houses burn hot. The houses next door in a suburb are usually close enough that they are going to take a lot of heat. Once a window fails it's all over.
Anything that burns vigorously in a strong wind sends a lot of embers downwind. So not only does the fire go from house to house, there's also spot fires in front of of the fire front.
That's pretty much impossible to fight once it gets to a certain size.
It's interesting that a lot of pics of burnt houses in LA show burnt husks of houses with intact vegetation around them. The houses are more flammable.
Many of the houses in Altadena and Palisades were older. That usually means more flammable. California upgraded building codes for areas in the WUI to include a bunch of measures to reduce ignition potential. The houses built to that code in Paradise did significantly better than the average house.
We could apply that to all houses. But it would only get done on new houses and those that are significantly remodeled. Which will be a low percentage in most places. It'd have to be a mandated retrofit to be really useful and Americans hate it when the government tells them what to do. So that's not happening.
I'll take fire and earthquakes myself.
/ Real estate General topic #668
The push now is to build infill and ADU 3' from lot line as increasing housing is priority one.
Window glass failure is often the precursor if the roof is ceramic or cement.
I've been told triple pane windows are better in several ways and fire rated shutters could go a long way and not usually difficult.
I live in an area where trees are sacrosanct and often within arms length of structures after protected for decades...
On a side note read some stats that man made is by far the leading cause of fire loss... on purpose or negligence...
/ Real estate General topic #669
It must be some universal quirk of human nature, that we're all more comfortable with our own local disasters, than those we see others suffer through on TV. Tornados terrify the mid-Atlantic folk, and Hurricanes terrify those living in earthquake zones. :D
Fire is the one that bothers me most. I'm fine with our hurricanes, but I chose and maintain my house accordingly. We did have a rare tornado do a bunch of damage in our area five years ago, but the folks in Oklahoma would've probably laughed at the thing, only upper Eff-1 territory. It did help straighten the previously-leaning steeple on my church, built 1740's... hand of God?
/ Real estate General topic #670
As a native Californian I find hurricanes and especially tornadoes terrifying. We don't get those. I have some understanding of fire having spent a few years on fire crews. I used to enjoy earthquakes until the '89 one which was the first that actually had me worried.
Here's a pic of a burned out house from the Palisades fire that I grabbed at random, literally the first I clicked on in the tool to check building status:
719
There's a lot of pics like this, with intact vegetation around the house. Those trees appear to be Eucalyptus which are famous for being highly flammable. They didn't even burn. The houses are the fuel. Tree preservation ordinances aren't the problem here.
I hope the residents got out with all that was important to them, they're safe and housed now, and they can rebuild quickly.
/ Real estate General topic #671
Another mention of ADUs, increasing housing density and making sure fires have fuel.
Wife's cousins have 3 in the neighboring 4 house yards.
Noise, having a new view of the back of a small house etc.
More firewood.
Welcome to the next fast traveling fire.
Unit density is a very double edged sword. Denser allows lower pricing, and also less vegetation to start fires, and all; but it also can make the fires harder to fight. Now, maybe they can regulate say, 25 ft fire breaks on the perimeter of new communities, like we have 25 ft landscape buffers? At the same time, you also have the question of how much you want the state/county/city regulating private property land use...
Edit: I don't know that 25 ft fire breaks would change much, or if 50 ft would work, but you also reach a point where you can't realistically mandate 200 ft, and still be able to build functional developments
/ Real estate General topic #673
I was talking with my previous insurance agent many years ago and mentioned we had the roof replaced with a metal roofing, and was told the premium will go up due to higher replacement cost!
/ Real estate General topic #674
When I got roof quotes about 2 years ago, there wasn’t much difference between shingles and a screw down metal roof. Standing seam different situation.
Metal roofs vary widely. I've never liked the screw directly through singles to OSB installation. I prefer 1x4 (or 2x4) firing strips.
When I redid mine, I did want to do metal, but it was going to be around $2500 vs $1500 for shingles, and also i had a short time line, and shingles were fast.
/ Real estate General topic #676
I would never suggest relying on screws into Osb without using pine furing strips. Also, using dome head screws should extend the life of the sealing gaskets compared to screws where the gasket edges are exposed.
The actual lifespan of today’s shingles vs screw down roofs, I don’t know.
/ Real estate General topic #677
I was told the mandated shake had to go so I went with high end Presidential Comp Laminated shingles... with permit.
The reroof cost the same as the home did new.
Agent said I will see a rate reduction but when submitted company said underwriting changed and no credit for the new roof.
/ Real estate General topic #678
719
Maybe it depends on the type of fire?
Santa Cruz was a canapy fire in very tall redwoods and nothing done at ground level would have done much to mitigate
/ Real estate General topic #679
25 ft fire breaks on the perimeter of new communities…
25 ft isn’t a “fire break”, its
A “spark gap”. 😀
I grew up “in town”, cordoned blocks of 3/4 or 1 acre, block after block after block. It allowed a reasonable 200 feet on-center spacing of houses, so more than 100 feet between nearest walls. Didn’t seem unreasonable, it was still relatively “high density”.
A “spark gap”.
That means you need atleast 1 acre per home, and in a population density of that, that's asking an aweful lot. Also, by default, that would raise the costs of the developments. It's not an easy solution.
Also, there is risk in every place. Hurricanes in gulf and SE, earthquakes in Cali/PNW/Ask and Ozarks, tornados are basically a nation wide thing, fires, blizzards, ect.
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2015 FREIGHTLINER...
2013 Ford Escape SUV (A64557)
2013 Ford Escape...
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
2015 Chevrolet Tahoe SUV (A64557)
2015 Chevrolet...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A67148)
2023 KENWORTH T680...
