Won’t start after getting stuck in mud.
/ Won’t start after getting stuck in mud. #21
Since so far away from barn, turn key to on position, confirm fuel cutoff solenoid actuated to allow to run and hot-wire to starter post and get running. If cold hot-wire to glow plugs of intake air heater.
At least you can get back to the barn to figured out problem
Turning Key to stop should kill engine when solenoid drops out or kill fuel at shut off.
Interlocks only needed at start. This bypasses all of them. Just bring power to starter solinoid connection. Usually a spade or ring connection. Only needed light gauge hot-wire. Ten or twelve. Put a fuse in series if concerned.
/ Won’t start after getting stuck in mud. #22
Newbie here. MT357HC under 10 hours I got stuck in some mud and forgot about the option to switch to 4wd so I spun the tires and kept reversing and forwarding trying to get out. Once I remembered 4wd I got out easily. I turned the tractor off to walk and check out the area. Got back in and it won’t start. Will turn on but won’t crank or even attempt to crank. I’ve read that safety switches commonly cause this. It just beeps. Battery is fine. Are there any specific safety switch’s you think I hit while stuck and trying to get out? Anything else you can think of? Thank you.
On both of my LS tractors, I often get stuff stuck in the pedal safety switch (which is under the tractor). Then the tractor won't even turn over. Now it's the first spot I check.
/ Won’t start after getting stuck in mud. #23
Put it in neutral and push in the clutch pedal
/ Won’t start after getting stuck in mud. #26
Like yours mine would not start and after several days looking for the problem I found a loose wire on safety switch under the seat, also on mine the seat belt has to be engaged or it wont start.
/ Won’t start after getting stuck in mud. #27
The OP hasn't been back on the site since Jan 5th. Looks like he joined just to post the question and must have gotten it fixed so he left.
/ Won’t start after getting stuck in mud. #28
I hope the OP posts his result. It could help someone else with a similar problem in the future.
/ Won’t start after getting stuck in mud. #29
Just a few things I would check
Is the power take off turned off ?
Is the shift lever in neutral ?
Is the parking brake set ?
Also if it has hydrostatic drive my Kubota foot pedal has to be centered between reverse and neutral. With the cold weather mine has stated sticking
I’m sorry for the late update. I’ve tried all I could so my dealer is going to send out a technician. I don’t have an appointment date yet but I will definitely update when I find out what happened.
Unfortunately I didn’t get it fixed but when the dealer’s technician comes out I will let you guys know. This is my first tractor so I will definitely be using this wealth of info on the site and I’m sure I’ll have more questions in the future. And I really appreciate everyone’s tips to try and figure this out in my own. Is there an app for this site? All the notifications I got in my email were buried in tons of junk mail. I just so happened to see an email this morning about a comment.
I can’t really figure out how to get under the seat in my cab model but I do see the wires behind the seat and they look ok.
I rinsed under the tractor incase there was mud affecting any contact. I’ve looked under there and don’t see anything obviously unconnected or anything stuck. I’m not sure exactly where the pedal safety switch is but I’ve looked under the area of the pedals and don’t see anything stuck. I bought the maintenance manual for the tractor hoping I could figure it out in my own but no such luck. Is there anyway you could take a picture of where the pedal safety switch is? I know it’s cold everywhere so I totally understand if you can’t right now! I have the HST model if that makes a difference.
/ Won’t start after getting stuck in mud. #34
Here is the LS parts site may be helpful
Welcome!! LSMtron Web Parts Catalog
/ Won’t start after getting stuck in mud. #35
As a rule of thumb, remember that, if mud contains a significant amount of iron, it can cause a short circuit, esp. when wet, but even when dry. I had mud wasps build a nest inside one of my brush cutters. It wouldn't start & I even wore out the pull cord trying. In replacing the pull cord I discovered the wasp nest & removed it. The thing started right up & ran fine thereafter.
/ Won’t start after getting stuck in mud. #36
Another way to help get out ot if stuck is use your front end loader to put your bucket out semi open and roll the bucket in with the tractor pulling , the bucket has helped me out of a bog more times than 4 wd. I know this is no help with the no start but it will be a tremendous help when stuck.
Finally got the dealers technician out and they were not able to figure it out onsite so they are bringing it in to the shop. I will update when I have the answer. Onsite he was unable to bypass the starter. There was an IMV error code.
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2024 Linx UT357714T 7'X14' Single Axle Trailer (A60463)
2024 Linx...
26120 (A56859)
26120 (A56859)
207272 (A52708)
207272 (A52708)
2021 JOHN DEERE 204L WHEEL LOADER (A62129)
2021 JOHN DEERE...
