3720 open station 3ph lever getting loose
   / 3720 open station 3ph lever getting loose #1
fishhead
Gold Member
my lift lever has loosened up and will no longer stay back. My understanding is that i should try to tighten the nut on the end of the shaft and if that doesn't work then the friction washers need replacement. On the GTT forum a poster was saying i need to remove the wheel and fender- does anyone know if that can be avoided and how best to access?
Thanks
   / 3720 open station 3ph lever getting loose #2
Removing likely offers better access so makes the task easier. Not a major job to remove. Just go slowly and carefully.
Thanks
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A56436)
Bulk Lot of over...
CFG Industry H15R Mini Excavator (A57149)
CFG Industry H15R...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
DEUTZ MARATHON...
2007 Oshkosh S-Series TMMB 11 Yard Front Discharge Concrete Mixer Truck w/ Tag Axle (A56858)
2007 Oshkosh...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
