RX7340 radio upgrade and spinning knob
/ RX7340 radio upgrade and spinning knob #1
cutthroat
MO
Kioti RX7340PC
Did some additional mods this afternoon. Found the factory radio to be crap and didn't support handsfree with my phone. Upgraded to a Continental TR7412UB-OR radio. Got radio from tractorradios site because it included the correct wire harness and an additional faceplate if needed. Was a little more expensive than could get from other places, but the convenience of the correct harness was worth the additional price. The new RX40 series has the newer 12 pin radio harness other newer Kioti's are using. The one good thing with the factory radio was I was able to reuse the faceplate to cover up the factory screw mounting points that I didn't use with the new radio. I did have to remove some of the plastic tabs on the plate so it fit flush with the new radio. I also found a Kioti branded spinning knob and got it installed.
/ RX7340 radio upgrade and spinning knob #2
I ordered a powered sub woofer for my compact cab tractor. I'll update when it comes and I get a chance to wire it up. Where did you find the steering wheel spinner?
Got knob from ebay, PerryPower.
-Craig
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
Towable Centrifugal Water Pump (A59228)
Towable...
2007 Ingersoll Rand P185 S/A Towable Air Compressor (A59228)
2007 Ingersoll...
2014 Top Hat Trailer (A60352)
2014 Top Hat...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2015 Ford F-150...
