I Stink At Removing Snow From My Gravel Driveway
   / I Stink At Removing Snow From My Gravel Driveway #1
snpower
Gold Member
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
Here in Virginia we are having our 2 x per decade decent snow event. I have a #8 brownstone driveway and I've never been very good at getting the snow off with my JD 1025R.
I have a rear blade, which requires constant attention to keep from gouging. I have put PVC on my loader and use it in float mode. Not so great honestly. The best luck I've had is backdragging in float mode with the PVC installed on the loader edge. It doesn't get to the surface but it also doesn't displace the stone. I am thinking it's the best case scenario.
What am I missing, if anything here? Edge Tamers?
   / I Stink At Removing Snow From My Gravel Driveway #2
I use the tamers, these below, you may need 3 depending how heavy the bucket and how soft the ground is.
I can run in float at almost full speed with out digging in.
   / I Stink At Removing Snow From My Gravel Driveway #3
Turn your rear blade around 180 deg. so it won't dig in.
   / I Stink At Removing Snow From My Gravel Driveway #4
I'm in the same boat, but we get a lot of snow...
I couldn't pull the trigger on the "originals" so I found these to try and not hurt if it doesn't work. Paid $31 delivered, waiting on delivery now.
   / I Stink At Removing Snow From My Gravel Driveway #5
I got a $100 snow blower this week on Marketplace, then made wooden skids that are wide and taller. Leaves 1" of snow, but glides along nicely.
Decided it would leave the driveway surface in better shape than the tractor
   / I Stink At Removing Snow From My Gravel Driveway #6
skid shoes on the rear blade? I use a rear blade and I was thinking of just bolting on a couple blocks of hardwood from the firewood pile to see if i would would work? Plowing on unfrozen gravel is a pain. I've also considered just angle grinding the rear blade cutting edge to a less aggressive angle.... It's junk for moving dirt anyways, so I haven't used it for that in 10 years since I got my box blade.
   / I Stink At Removing Snow From My Gravel Driveway #7
Far as I'm concerned there is no reason to remove snow right down to dirt/gravel/pavement level. Keep your blade a couple inches above the ground and it won't dig in and you can still drive on it without getting stuck.
   / I Stink At Removing Snow From My Gravel Driveway #8
You can put gauge wheels on the rear blade to hold it up a little. I keep mine 1.5" off the gravel and have very little disturbance of the surface.
Also, if you're plowing with your bucket (and don't have edge tamers) you can set your bucket so the lip is about an inch off the ground and then put it in float. It will ride over the snow and you can "bump" your dump/curl function to make fine adjustments to get it to dig a little more or less.
PS: Don't be too hard on yourself, I've been trying to do it for 17 years and still can't keep the rear blade from digging it without gauge wheels.
   / I Stink At Removing Snow From My Gravel Driveway #9
An easy fix. Turn your rear blade around 180 degrees so the cutting edge faces backwards. The float the blade and drive forwards. This will remove snow without disturbing your gravel. If the snow is deep also hold your loader bucket 4 inches above the road to move the greater depth and follow with your reversed rear blade.
   / I Stink At Removing Snow From My Gravel Driveway #10
I NEVER use the blade in the "forward" position on gravel. Pushing snow with the wrong side of the blade won't dig in, as you say. (y) I did make shoes for the blade which works too.
2010 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2010 Chevrolet...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
New Holland WorkMaster 37 (A53317)
New Holland...
2006 CEI  DRY BULK TRAILER (A58214)
2006 CEI DRY BULK...
2006 TRANSCRAFT 48X102 SPREAD AXLE FLATBED (A58214)
2006 TRANSCRAFT...
PALLET OF BANISTER RAIL, MOLDING (A58374)
PALLET OF BANISTER...
