CT335 won't deliver fuel to injectors - fixed
   / CT335 won't deliver fuel to injectors - fixed #1
celicaxx
Wetumpka, AL
First, I want to thank people here and YouTube that share their troubleshooting and repairs.
I was going to flush my radiator and put in some fresh antifreeze mix, but the tractor wouldn't start/run, so I thought since it only spun over a few revolutions, it was just low on battery power. Charged the battery up, but it still wouldn't run after cranking.
Checked the fuel: getting fuel to the lift pump, fuel bowl was full, fuel inlet to the injection pump was getting fuel. But when I checked for fuel going out of the injection pump, nothing. No fuel coming out from any line I cracked open.
I shot a little starting fluid in the intake, and it fired up but wouldn't stay running. Checked fuses; all were good.
Gave up and researched this forum first, then went to YouTube to look at injection pumps, relays, and solenoids. I kept circling back to the fuel stop solenoid....seemed to be a legit ailment and the check was simple enough.
Checked the solenoid today after pulling it off the pump; solenoid did not retract and the tractor ran!
Now I know what to fix.
For the hell of it, I took it apart to see what it looks like internally, put it back together, and now the damn thing works.🤔
I'm still going to source a spare solenoid just to have
   / CT335 won't deliver fuel to injectors - fixed #2
I suspect dirty electrical connections. Unplugging and plugging back in may have provider the fix.
I would have thought the same, but I had disconnected and reconnected the plug a few times, then I tested the unit while plugged in but not installed. It didn't function, so I decided to disassemble.
Regardless, I think having a spare would not be a bad idea
197711 (A51244)
197711 (A51244)
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2012 CATERPILLAR 305DCR EXCAVATOR (A52707)
2012 CATERPILLAR...
2024 ArmorLite Aluminum End Dump Trailer (A55314)
2024 ArmorLite...
2018 Altec DC1317 Towable Brush Chipper (A55851)
2018 Altec DC1317...
2014 Jeep Patriot SUV (A53424)
2014 Jeep Patriot...
