What is some of your Pet Peeve's
   / What is some of your Pet Peeve's #1,691
Just got back from a bit of a highway road trip. I use cruise control alot, bad knees. And it happens all the time that the car being overtaken will realize they are just under the posted speed, so they speed up while you are attempting on overtake. And will follow you side by side till I have to go much faster, or go off the cruise control setting to fall back. If I fall back, they will then settle back in to a slower than posted speed. And then repeat the same actions when you later want to over take them.
One of the more modern car features that I love is adaptive cruise control. I can set it for the speed that I would like to go, and the car maintains a safe following distance with the car in front of me.
I find that I am more tolerant of cars in front of me that are varying their speed. If the car has been consistently traveling slower than my desired speed, and I have a good break in traffic behind me, then I'll try going around. Otherwise, it's easier to just wait in line. I'm not in that big of a hurry anymore.
   / What is some of your Pet Peeve's #1,692
My company Tundra has that. I don't use it because even at the highest setting it follows to close.
   / What is some of your Pet Peeve's #1,693
I “HAD” those problems until I started heating the cans..
Really HOT water works too..
Last couple of days/weeks we’ve had some cold temps in the 20’s/30’s.. enough to pull out the electric heater..
I simply put the can on it or in front of it and pick it up a time or 3 and give it a good shake and no more spritz..
Like I said, real hot water works too..
That might be worth a try, but my shop is heated and air-conditioned, so it wasn't real cold to begin with. I keep it set at 55F/85F when I'm not out there, so it was probably 55-57F when I first went out this morning, but I had already turned the heat up to 63F hours before spraying.
So, the cans weren't exactly hot or warm, but they were probably somewhere close to 60F... not very cold.
   / What is some of your Pet Peeve's #1,694
I use a lot of Rustoleum and have very little trouble. If you look at the nozzle the tip can be removed with a pocket knife (most tips) and a drop of Brake-Kleen and rubber tipped air gun usually cleans it out. I never ever turn can upside down blowing out after use and have 30 yo cans still spray. If tube going into can is clogged, which almost never happens with me, I put a drop of brake cleaner on top and shop air sprayed down in.
I always shake can a lot before use and during spray. Any trouble usually is the nozzle so I save good nozzles from empty can as well as the marble inside!
   / What is some of your Pet Peeve's #1,695
I use a lot of Rustoleum and have very little trouble. \
I never have trouble with the traditional white cans, either. This was the Farm and Implement product, though. I don't think they make a good "JD Green" in the traditional product line.
Yep, done that. But these weren't clogged in the nozzle, it was clogged down inside the can.
I always do this. I still remember being taught this trick ca.1980, as a kid who basically lived in dad's or grandpop's shops.
Okay, I gotta see this move! Sounds scary.
   / What is some of your Pet Peeve's #1,696
When I finish spraying paint, I always pull the nozzle off the paint can and then pull the nozzle off a can of carb cleaner. Then, I put the paint nozzle on the carb cleaner can (or hold it tightly over the tube sticking out the top) with a rag around it and spray a shot of carb cleaner through the paint nozzle. Prevents most spraying problems on the next use.
I also spray a little carb cleaner down into the tube of the paint can before I put the nozzle back on.
Finally, I keep a stock of known good nozzles of various types in stock in case of emergency.
Seems I've read somewhere that they changed something about the paint cans such that spraying upside down doesn't empty out the nozzle anymore. That comports with my experience also.
   / What is some of your Pet Peeve's #1,697
“When I finish spraying paint, I always pull the nozzle off the paint can and then pull the nozzle off a can of carb cleaner. Then, I put the paint nozzle on the carb cleaner can (or hold it tightly over the tube sticking out the top) with a rag around it and spray a shot of carb cleaner through the paintnozzle. Prevents most spraying problems on the next use.”
Great idea! Will have to try it!👍🏻
   / What is some of your Pet Peeve's #1,699
I still have some new 30 year old cans and grabbed one last week and sprayed perfect… semi flat black from the 90’s
I still have a couple of cans of black and silver spray paint that I know were bought in the late 70s, and they still work, I just used some of the black last week.
   / What is some of your Pet Peeve's #1,700
Same. Just like old refrigerators, old spray cans work fine. It's only the new ones that fail.
2013 Genie GTH844 8K Capacity Telehandler (A59213)
2013 Genie GTH844...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
2014 Mercedes GL450 AWD SUV (A56859)
2014 Mercedes...
2015 Komatsu PC490LC-11 Hydraulic Excavator, S/N A42603, PIN# KMTPC251HFWA42603, Turbo Diesel (A59076)
2015 Komatsu...
2011 Ford E-350 Cargo Van (A56858)
2011 Ford E-350...
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
