Hydraulic Transmission Fluid
/ Hydraulic Transmission Fluid #1
Portuguese Farmer
Central Portugal
Mitsubishi MTU26R
The book states this goes in the trans., and front differential, that's all it states, any ideas?
I found trans. fluid and hydraulic fluid. Thanks in advance.
/ Hydraulic Transmission Fluid #2
What you want is UTTO - Universal tractor transmission oil.
This is transmission fluid made to be used in hydraulic systems and transmissions that have wet clutches or wet brakes. Your tractor has both.
I'm using Petronas MTF 10W30, which can be used in your Mitsubishi as well. There are other brands.
Agripeixoto has a good online store if you need.
For the front axle, I like to use 80W90.
Much thanks👍🏼
/ Hydraulic Transmission Fluid #5
I am not so good at it. I have previously seen on the internet that it's possible to use only universal tractor transmission oil. Or it's possible to use some specific one?
/ Hydraulic Transmission Fluid #6
Several companies say you can use either universal transmission oil or gear oil in the front axle on tractor with mechanical front wheel assist.
Hydraulics reservoir (typically transaxle) must always use universal tractor transmission fluid
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
KUBOTA L47 BACKHOE (A62129)
KUBOTA L47 BACKHOE...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
2023 Kearney 7'x14' Trailer (A60462)
2023 Kearney...
